Compression question
  • CUBuffs
    • 252
    • Castle Rock, Co
    Even if the smoke is only coming from #1 I should just leave it be for a while?
    80 XS11 SG
    79 XS750 SF
    74 KZ400
    78 KZ650
    78 KZ750
    • CUBuffs
      • 252
      • Castle Rock, Co
      I guess what I really mean is if I put the exhaust on correctly should it be smoking out the #1 port?
      80 XS11 SG
      79 XS750 SF
      74 KZ400
      78 KZ650
      78 KZ750
      • CUBuffs
        • 252
        • Castle Rock, Co
        Rough Idle
        OK, it's raining here today but thought to let the bike idle for a while after putting it back together.
        With the choke out it started and run for a short time then I tried pushing the choke in but it started coughing, so I pulled it out again and it idled for a couple minutes then died, and won't start again. I have not put the air filter back on the box yet but would that cause the problem? I'm not sure what to look at.
        80 XS11 SG
        79 XS750 SF
        74 KZ400
        78 KZ650
        78 KZ750
          #34
          Silly Question Time
          Did you turn the fuel back on?
          • CUBuffs
            • 252
            • Castle Rock, Co
            #35
            Yes.
            I did put 4oz of Seafoam in the tank to clean out carbon in the valves, but I might only have about a gallon of gas in there. Can you have too much Seafoam in the tank?
            80 XS11 SG
            79 XS750 SF
            74 KZ400
            78 KZ650
            78 KZ750
            • CUBuffs
              • 252
              • Castle Rock, Co
              #36
              It's running now
              I know that the fuel was in the "ON" position but I decided to put it on "prime" for a few seconds each side then placed it back to "ON". It fired up and stayed idling but smokin' bigtime--I suppose it's the Seafoam working.
              Anyhow, I know I primed it last night before I fired it up then. Don't know why it needed it again.
              80 XS11 SG
              79 XS750 SF
              74 KZ400
              78 KZ650
              78 KZ750
              • wingnut
                • 695
                • NC
                #37
                Bubble, Bubble toil and trouble
                I have clear fuel lines on the SH and some times notice air in the lines, up on the octopus, if it sits for a couple of days. No leaks and no fuel in the air box. How ever it gets there I have had It stumble while running with the choke out . Just feels like it starved for fuel for a second. Push thru it with throttle and the problem goes away along with the visable air bubbles.
                wingnut
                81 SH (Daily Ride)
                81 XS 400
                Thomas Jefferson
                • CUBuffs
                  • 252
                  • Castle Rock, Co
                  #38
                  Wingnut,
                  Thanks for the info.
                  80 XS11 SG
                  79 XS750 SF
                  74 KZ400
                  78 KZ650
                  78 KZ750
                    #39
                    His Smoking Problem!!
                    Here's what I PM'd CUBuffs recently about his #2 cylinder smoking problem, then sent a second one also mentioning he might have a stuck OIL PISTON RING!? Any other thoughts!
                    I was thinking a bit more about your situation though, and regrettably came up with some "bad" thoughts!
                    Was thinking about the WHY part of how this cylinder/valve got bad, and realized that more than likely, it either has a leaking valve seal, the rubber one just beneath the valve springs that keeps the cam chamber oil OUT, or AND...the valve guide seal is also blown...there's a rubber Oring around it which also keeps the oil from dripping down the valve stem and INTO the engine's combustion chamber. Oil makes smoke, and it also doesn't burn very well compared to Gas, and so it may be the WHY that valve got all gummed, carboned up and messed up the seat and valve head/lip!!
                    So....it looks like you may be in for having to pull the head and do a VALVE job on it anyways, along with having a shop check to verify that the leak is from the Valve stem seal, vs. the valve Guide Seal/Oring!? Sorry for the bad news, and putting you thru the other work for possibly naught!?
                    • CUBuffs
                      • 252
                      • Castle Rock, Co
                      #40
                      no smoke today
                      I fired up the beast again today and let it idle. There was no noticeable smoke this time. There was however some popping sounds when I would give it some gas when first warming up. After about 5 minutes the popping disappeared and it sounded good.
                      80 XS11 SG
                      79 XS750 SF
                      74 KZ400
                      78 KZ650
                      78 KZ750
                      • CUBuffs
                        • 252
                        • Castle Rock, Co
                        #41
                        update
                        Let it sit for about an hour and started it again. As before it fires up but I get popping out the airbox when I give it gas---until it warms up for about 2 minutes.
                        80 XS11 SG
                        79 XS750 SF
                        74 KZ400
                        78 KZ650
                        78 KZ750
                        • GNEPIG
                          • Apr 2005
                          • 1656
                          • fl
                          #42
                          .. do you have to use the choke to start your bike when your engine is cold? could still be a little lean at idle. if it idles and runs good when it's warm then i would not mess with it anymore. no carburated anything runs good when cold
                          .. ride it ..
                          • CUBuffs
                            • 252
                            • Castle Rock, Co
                            #43
                            Gnepig,
                            Yes, I do use the choke to start. T.C. suggested I throw on some new plugs, so I think I will do that and just leave it alone for awhile. It does seem to run pretty smooth after it warms up. Just never had it poppin' before I sprayed the Deep Creep into the valves.
                            80 XS11 SG
                            79 XS750 SF
                            74 KZ400
                            78 KZ650
                            78 KZ750
                            • wingnut
                              • 695
                              • NC
                              #44
                              That poppen you hear is prob just a lean condition from being cold. These things do not like to be lean and until they get nice and warm they will act funny. I start mine on choke,let it sit for a minute then kick it down to half choke. I can ride it on half choke if I'm not to agressive with the throttle. Half a mile down the road I kick the choke off and it runs normal after that. If you hear the same noise when decelerating its also a sign that at least one cyl is a little lean or you are not quite sync'ed. Sounds like you got it running good and the smoke went away so ride on!
                              wingnut
                              81 SH (Daily Ride)
                              81 XS 400
                              Thomas Jefferson
                              • CUBuffs
                                • 252
                                • Castle Rock, Co
                                #45
                                Engine Kills
                                Thanks Wingnut,
                                I took the beast for a short (1 mile) ride to Sears, parked it for 10 minutes, came out and fired it up without choke, after about .2 miles the engine started running very rough and it killed.
                                I put fuel on reserve just in case but it would not start unless I opened up the choke halfway and it revved very high. I put the choke back in and kept giving it gas. It ran for about another .5 miles or so and did the same thing---killed as I was pulling on to my street. Anybody got an idea for me?
                                80 XS11 SG
                                79 XS750 SF
                                74 KZ400
                                78 KZ650
                                78 KZ750
