Front Tire wohs!
  • Artic_rider
    • Apr 2005
    • 130
    • Grande Prairie, AB
    Front Tire wohs!
    Damn question...yada yada yada...
    Went to put on a new front tire yesterday, and when I loosened the nut on the bolt, the forks closed in on me, making it a bitch to take the tire off...not to mention getting it back on. Any one experianced this? Did I do something wrong in the prosses?
    80' Xs eleven special "The Tank"
  • pit-fighter
    • Jan 2006
    • 55
    • Knoxville,TN
    Let the air out of the tire..then put it on.
    • Artic_rider
      • Apr 2005
      • 130
      tire was flat when it went off, and back on
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "Bent fork tube?"
        I'd have to see the situation to figger it out.
        • AKMac
          • Sep 2005
          • 141
          • Utah
          Wait, do you mean "closed in" as in the lower fork rotated? If that's the case then all you need to do is let the air pressure out of the forks, and move it by hand so it aligns back up.
          1979 XS1100 Special (Chrome Queen)
          • Snow
            • Oct 2002
            • 1041
            • Tallahassee, FL
            I found that removing one of the brake calipers on my standard allows me to remove the front wheel with *much* more ease than letting all the air out of the tire. Much less drama.
            • Do Lee
              • Feb 2003
              • 255
              • Victoria, Texas
              On the Special model I always remove the fender which allows me to twist the forks moving the brake calipers out of the way to remove the wheel. After replacing the tire, reinstall the wheel in reverse order.
              Do'Lee
              XS1100SF "Green Hornet"
              (1) XS1100LG "Midnight Dream" Restoration has begun.
              (2) XS1100LG "Midnight Madness" Waiting to be next
              (5) multi partsters for bobber "Ruby Red II" On the list.
              SR500H "Silver Streak"
              • Snow
                • Oct 2002
                • 1041
                • Tallahassee, FL
                Forgot to mention - I have a Tkat forkbrace - you can no longer just let the air out of the tire and turn the forks out of the way with this brace.
