Jetting 82 xj100
  • imanightsurfer
    • Apr 2006
    • 35
    • Indiana
    Jetting 82 xj100
    Can someone help i,ve got a 82 xj11 and put a 4 into 1 open header took out the airbox and replaced with pod filters and I know I have to rejet it. Any ideas how big I should Start with i found a guide line by Denny but it says it's for 78 thru 81 I have
    an 82 with XS650 Mikuni 34mm carbs will the same guidelines work?
    nytesurfer
    82 xj1100
    80 xs1100 special
    83 xs650 Sold
    84 fj600 Sold
    70 BSA chopper (old school) Sold
    Down to my two BEST
  • Rubin
    • Apr 2003
    • 115
    • Windsor, Ont
    I have the same setup and just followed the guidlines listed for the XS, then narrowed it down checking the plugs using the "chop" method. Unfortunately I did not write down the final settings on my carbs or I would post them for you as a starting point, though as always ymmv.
    1984 XJ1100 - 79 cams, XS850 FD, XS triple tree/euro cafe bars, hydraulic clutch, bar end mirrors, yamaha R1 rear mono-shock
    1972 CL350 - clubmans, Mike's XS coils/condenser, '98 Yamaha R1 rearsets (If I can find some at a decent price)
    • xj11john
      • Jun 2005
      • 440
      • Lafayette, TN
      I have the same set up as you, I went with 122.5 mains and left pilots stock, I believe stock for the xj was 47.5. Went out with idle screws 3 or 4 turns and had it syncronized. Runs good.
      '82 Xj1100j
      "Ride for the Son"
      John
