Chrome goodness!
  • AKMac
    • Sep 2005
    • 141
    • Utah
    I'm almost certain that I have the holes facing the right way. I better re-check since she's getting rubber tomorrow I do remember buying two extra set's of disc brake locks just in case though
    I'll try to document the control swap process as much as possible. I'll be honest though, I'm not very good at electrical stuff. So far it seems like a pretty straight forward swap as all the wire colors match the XS11 wiring diagram exactly, though there is an extra black wire (ground) on the left control that I'll have to find a home for.
    For polishing the cooling fins I've had good luck with first sanding them down with fine grit emery cloth on a flat sanding block. You'll know when your done when you can no longer see any machining grooves in the edge of the fin. After that I take a felt drum dremel attachment, load the drum with jeweler's rouge, and going to town. The fin edges look like chrome after this, but unfortunately it does take some time.
    1979 XS1100 Special (Chrome Queen)
    • bikenutt1980
      • Jul 2007
      • 139
      • omaha,ne
      ok whos Mikexs?
      • Bigfoot
        XS-XJ GURU
        • Sep 2005
        • 1422
        • Kansas City, Missouri
        http://www.mikesxs.com/
        Harry
        '79 Standard
        '82 XJ1100
        '84 FJ1100
        Acta Non Verba
        • Hammerhead1st
          XStremely XSive(Deceased)
          • Jul 2007
          • 330
          • Lawrencvile, GA
          #34
          I went the other route...blue paint marker on the fin edges...took an hour and no rubbing!! LOL...actually it's a temp solution till I put her up for the winter. Gonna do an engine off cleanup, although I'd never afford to do THAT!! Those are some SWEET parts and I'd KILL for that look when you're done! I think they should chrome all parts over 25 yrs old for free as a matter of national aesthetics...
          "Rat Rod"
          79 XS1100 Standard
          87 VMAX cans
          Cheap Japanese Tires
          Cobalt Blue Rattle Can Paint
          Custom Lighting on a Budget
          Perry Center Fire Department
          Perry Emergency Ambulance
          "If we don't do it, who will?"
          Some people have one of those days, I have one of those lives...
          • firecrackerboom
            • Jul 2007
            • 81
            • South Dakota
            #35
            did he ever have any pics of when it was done?
            1979 Eleven Special - 26,000 miles.
            • bikenutt1980
              • Jul 2007
              • 139
              • omaha,ne
              #36
              yep.
              • dragxs11
                • Jun 2003
                • 519
                • Reno, NV
                #37
                Gonna be nice AKMac, you've done a few things I wish I had known to do. Never thought of use mikexs parts. Like the switches and bar clamp.
                Wetrock.... you can chrome, black chrome the rear wheel w/out removing the dampeners. You don't wanna take those out... probably can't without a really good hydraulic press. Powdercoating requires removal of them tho... for the oven. I've done it, but I needed a spare wheel cause I ruined 3 dampeners pressing them in and out. The other thing is they need to be set back in right on or the wheel might wobble, eat bearings, etc.
                1980sg-Stocker-- Sold
                1980sg- Cruise Missile- Sold to RODS454
                1990 ATK 604- Ditch Digger
                2005 BMW K1200S- Killer Bee
                2005 Suzuki GSX-R 1000- trackbike
