#1 no spark coil to sparkplug
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    here i go again, in my euphoria in getting the beast to run, i didn't notice #1 cylinider was not getting spark; man it's fast on 3 cylinders.
    i looked at tech tips more thoroughly this time, but found nothing, and i need help again thanks in advance.
    apparently i found a new invoice from a yamaha dealer that the previous owner bought and had installed a new coil and caps, $140.00 for parts alone, sad indeed.
    and in this invoice it states coil 1&4 and i guess for you Xsessive Techicians, i can guess this mean one coil runs 1 and 4 and the other runs 2 and 3, correct me if i am wrong.
    i first notice a cold header pipe and pulled the plug no spark, all others has them, can i eliminate the coil as the culprit?
    i'm sure you will know the diagnostic procedure, i'm a better with wrenches than electrons, so where do i start, i would be indebted.
    thanks again.
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    3 outa 4 ain't too bad!
    Hey Mason,
    Yes one coil fires both 1 and 4, the other 2 and 3. IF #4 is warm, then most likely the coil is working. Could be as simple as removing the cap, check the wire end for corrosion, clip back 1/4" from it, ALSO check the cap with ohmeter, should be about 5K, if much more than that, then it could be bad and should be replaced, otherwise stick cap back on.
    How did you check #1 for spark? IF it was with the #1 plug, it could have gotten gas fouled, and might not show a true spark. Try a new plug. ALso you can swap plug wires 1 with 4, they both fire at the same time, and run it and see if #1 warms up and if #4 stays cool!? IF so, then plug lead/cap for #1 that is NOW on #4 is bad. IF 4 gets warm, and 1 stays cool, check plug for presence of gas, wet=no spark, dry=no fuel!?
    That should get you further along!
    • mason79
      • Mar 2006
      • 1351
      • los angeles, ca
      thanks topcat,
      i was polishing the chrome today and the sensation of vintage era shape and design and the top qualty material felt through my fingers was awesome, i'm keeping this baby forever, my first bike was a 78 rd 400 maxed out by gary from spec II, this bike is the motherlode of all thing2 yamaha, the first 4 clylinder, not too shabby.
      so polishing was for today and the daylight is gone, the mechanical stuff maybe tue,
      btw, i didn't pull the plug, i pulled the plug wire, thanks i;ll look at the plug, can i get them at autozone?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        I've not had much luck finding plug caps(NGK) at local auto store, NAPA might be better, but MikesXS, Dennis Kirk I know have them, might be other places as well?
        Yeah, if you thought 3 cylinders was awesome, just wait till it's truly hitting on all fours....SHAZAAAM!!! It'll be love/lust at first throttle twist!
        IF you were talking about getting a new spark plug, there's a tech tip on spark plugs and what other brands and models you can use!
        • mason79
          • Mar 2006
          • 1351
          • los angeles, ca
          i haven't been able to get to the bike to try anything, but i want to find out since looking at some of the secondary wiring, 2 and 3 the insulation is cracking and that can't be good.
          i will need new wires or a coil if i don't want to attemped it myself, forget the coils, on the other hand if i'm going through the trouble, i like the accel 140403 remedie.
          so to better round out my knowledge:
          1) why is a 3 ohm impedance from accel not optimal for the 79f as a 1.5 ohm would be? is it because it would overload the ignition unit? with this put at risk the longevity of the ignition unit?
          2) on stock plug caps, why is it we need it to show any resistance, is this used to filter noise?
          3) do all caps have resistance?
          4) if i decice to put in wires instead of coils, and i leave resistor caps off and use rubber boots instead and get resister plugs as i have read in the tech tips, is this a viable alternative?
          5)what is the function of solid core vs. other types, am i retsricted to one type?
          any comment would help?
          thanks
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
            • 7694
            Here are some answers for you:
            1) the ignition system is set up with a "balast resistor", so the 1.5 Ohm will work, and the 3 Ohm won't, unless you bypass the resistor.
            2) Yes, the 5K ohm caps are for reducing noise.
            3) No, but you should use the resistance caps.
            4) It helps, but I run the caps and resistance plugs, with no problems.
            The solid core wire is noisy, the "carbon core" wires act like the resistance caps. The solid core will stand up to the vibrations from the engine much better than a carbon core wire.
            Just my $0.02
            Ray
            • mason79
              • Mar 2006
              • 1351
              • los angeles, ca
              that's worth 200 bucks. thanks
              come on now, only our bikes are cheap, but xsive wisedom to keep it alive.
              do you have any, comments on the aftermarket coils?
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
                Accel Shockingly overpriced!?
                Hey Mason,
                Check out this thread:Replacement Coil alternative
                Should be worth $144 worth of savings on those $200.00 coils! Also, MikesXs has the solid core wires, and plug caps, both resistor and NON resistor!!
                • mason79
                  • Mar 2006
                  • 1351
                  • los angeles, ca
                  thanks tiger
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • mason79
                    • Mar 2006
                    • 1351
                    • los angeles, ca
                    okay back to the spark thing and thanks in advance for any help
                    swapped plug wires 1 to 4 and 4 to 1, ONE still not firing, but 4 is, when i pull the wire off the spark plug , there is sometimes an intermitent weak spark i can feel in my hand, but the engine rpm does not go down and the pipe is cold, plug is wet from gas, swap #4 spark plug and it gets fouled the same.
                    coils:
                    measured impedance on primary side, my vom reads only a 1k setting so the 15 ohms requirement for the primary side shows zero, so far not clear
                    secondary side measures 20,000 ohms with caps and 15k without
                    all cap in tolerance at 5k good.
                    could this be pick up coil wires? please assist and thanks again
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                      • 7694
                      mason79
                      You have a carb problem with #1!!
                      The coil isn't firing because it's easier to go through the #4 plug.
                      I would check the float level on all carbs, and "bench test" the valve and seat for the fuel inlet. The "Tech Tips" on the left, or a search of the threads will give you plenty of information on this.
                      You may also want to do a compression test, if you have a gauge. Just to make sure you don't have any "hidden" problems.
                      Ray
                      • mason79
                        • Mar 2006
                        • 1351
                        • los angeles, ca
                        i checked the compression cold, i can't warm up the bike, # 1 does not run
                        #1 150
                        #2 175
                        #3 175
                        #4 132
                        i didnt put oil in to see if it's rings, maybe this weekend
                        looks ugly
                        4 runs 1 does not
                        i pulled out the plug for one and there is a weak spark when it's out of the cylinder.
                        is it because maybe ( i will check) the float for 1 is set too high or leaking and rendering a boarderline clylinder no to run?
                        any help would be appriciated.thanks in advance
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • turbopete
                          • Jun 2005
                          • 120
                          • Kent, U.K.
                          #1 150
                          #2 175
                          #3 175
                          #4 132
                          looks ugly
                          Those figures aren't enough to stop it firing on one cylinder. I'd say they were pretty good for a bike of that age.
                          • mason79
                            • Mar 2006
                            • 1351
                            • los angeles, ca
                            so turbopete,
                            what do those compression numbers mean?
                            how far off can they be and do you think i have to deal with internals anytime soon if i can get it running right at all?
                            History
                            85 Yamaha FJ 1100
                            79 yamaha xs1100f
                            03 honda cbr 600 f4
                            91 yamaha fzr 600
                            84 yamaha fj 1100
                            82 yamaha seca 750
                            87 yamaha fazer
                            86 yamaha maxim x
                            82 yamaha vision
                            78 yamaha rd 400
                            • John
                              • 5117
                              Did you hold the throttle open when you were cranking it over? A couple of the numbers seemed kinda high. The norm for these engines is around 140 and the cylinders should be within 10% of each other.
