knocking from the vacuum advance
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    dear xsirs,
    on to the next challenge, the bike idles great , however the was a loud knocking sound eminating from the engine, so i decided to recheck/thighen the cam chain
    1) do i tighten the stopper bolt to 4.3 ft/lbs, to mee that very tight, anyways it is all quiet, bu i'm concerned it is too tight, any comment would be apprieciated
    2) looking at thevacuum advance unit, it's going crazy knocking the crap out of the vacuum advance canister, what do yu think the problem is?
    that is what the knocking is, other that that the engine sounds seviceable and road worthy, yeah!!
    thanks for the help
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    Hey Mason,
    Glad to hear the second bench synch worked. Now....are you sure the vacuum advance hose is attached to the metal nipple on the #2 carb BODY, not to the #2 carb intake/synch port!?!?
    The vacuum pulses are much stronger from the intake boot, and can cause the thumping action you are getting from the vacuum advance module, whereas the carb body port is metered properly to provide the right vacuum with reduced pulses!
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      yes it's the advance hose is connected to the carb body, and i removed the canister altogether, and i think the entire mechanical advance mechanisim is rocking back and forth violently.
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        yes you are right, it worked, bike is alive!
        xs1100 rules!
        thank you very very much!!!!!
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • randy
          • Dec 2003
          • 4521
