Front wheel bearing question
  • AKMac
    • Sep 2005
    • 141
    • Utah
    I just received my replacement wheel bearings, and unlike the originals, these bearings have a shield on both sides. Should I remove one shield, or can I just install the bearing with both shields still intact?
    1979 XS1100 Special (Chrome Queen)
    Leave the shields on the bearings.
    Ray
      Ray
      The shielded bearings should be prelubed.
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        To avoid confusion...
        What John means is that the bearings are already lubed. Install them just the way they are.
        • AKMac
          • Sep 2005
          • 141
          • Utah
          Ok sounds good. I've never done wheel bearings before so forgive my ignorance, but since they are both prelubed, where if at all, should I pack some grease during installation?
            I would just put a THIN coating on the outside and inside meatal bearing surfaces, and on the axle bolt. Don't forget the clean and regrease the speedo drive as well.
            Ray
