OK, so I've been painting my carbs now for about a month. I've mixed up a couple of washers from the butterfly shafts. One of the washers is LARGE and hexogonal, looks like a big flat nut but it's keyed to fit the shaft under the locknut.
My question is:
Which carb uses this washer? Hint: I know it's not the #1 carb, cause I've asssembled the rest and this washer doesn't work on #1, I've tried it and it leaves too much play in the shaft
Someone with a detailed Yamaha shop manual should be able to look this up?
Thanks in advance.
My question is:
Thanks in advance.
