Carb help, please!
  • randy
    • Dec 2003
    • 4521
    Carb help, please!
    OK, so I've been painting my carbs now for about a month. I've mixed up a couple of washers from the butterfly shafts. One of the washers is LARGE and hexogonal, looks like a big flat nut but it's keyed to fit the shaft under the locknut.
    My question is:
    Which carb uses this washer? Hint: I know it's not the #1 carb, cause I've asssembled the rest and this washer doesn't work on #1, I've tried it and it leaves too much play in the shaft
    Someone with a detailed Yamaha shop manual should be able to look this up?
    Thanks in advance.
  • fxrer
    • Aug 2004
    • 241
    • Bethlehem, PA 18017
    If you’re talking about the nut on the end of the throttle shaft, on my SG, the two inner carbs (#2 & #3) have nuts. The outer carbs, #1 & #4 have a circlip over a washer that holds the shafts in place.
    Rick
    '80 SG
    '88 FXR
    '66 Spitfire MK II
    • randy
      • Dec 2003
      • 4521
      Hey, Rick!
      Yeah, some Specials have those circlips, but I've been looking at photos of the carbs on Ebay and it looks like the washer DOES go on carb#1, I just don't know how I've got so much slop on the side with the spring?
      You know, the sooner I get this done, the sooner we can scoot around LV!
      • btchalice
        • Jul 2005
        • 55
        • wichita, ks
        i took a pic of mine but dont know how to post it
        but the hex washer is right under the nut on #1
        79 xs1100 standard
        76 kz900 <now 1015
        Terry Meyer
