vacuum advance hose
  • CWilliamson
    • 175
    • Colorado Springs, Colorado
    vacuum advance hose
    How taut is the vacuum advance hose supposed to be? Mine just barely reaches the #2 carb and is stretched/bent over the port like it might restrict airflow. I guess I should just replace it but didn't know how much extra hose would be appropriate.
    Clark
    A couple of inches more might be nice...
    • Dragonrider
      • 1219
      • Garland, Texas
      Well, you certianly don't want it tight. That promotes kinks or cracks.
      Just get enough to route it out of the way and have an inch or so slack...you don't want too much either as it can kink due to the heat.
      CUAgain,
      Daniel Meyer
      • CWilliamson
        • 175
        thanks for the input...
        Yeah, is it supposed to go up and over the intakes or under and between? It wasn't connected when I bought the bike and I don't recall seeing a diagrahm for it. I couldn't find any vacuum hose that was small enough to fit through the engine case so I guess it'll have to be enlarged.
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          Get an inline barbed fitting and 'splice' on a new end (XStended length) at the carb end.
          engine ==old hose==<barbed fitting>==new hose== #2 carb nipple
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
          • CWilliamson
            • 175
            barbed connector...didn't think of that. I'll have to get one of those...
            Thanks,
            Clark
            • mro
              • 4276
              • Hayward, California
              Try a commercial lawn mower repair shop. Generally have all kinds of hoses to fit everything from little air cooled weed whackers on up.
              mro
              • Geezer
                • May 2003
                • 2985
                • Willamina, Oregon 97229
                I've never had a problem getting the right size hose at NAPA or other local auto parts stores.
                Geezer
                  The hose is 3/16". Can be found at any auto parts store.
                  • CWilliamson
                    • 175
                    The outside diameter of the 3/16" hose at the auto parts stores in my area is about twice the size of the hole in the engine that it is supposed to go through. I might check out a small engine shop...as mro suggests.
                      Clark,
                      Make sure you are looking at vacum hoses. Some of the fuel lines might work, but they are usually a lot larger outside diameter. I seem to remember the 1/8 will sometimes fit, depending on the hose manufacturer.
                      Ray
                      • CWilliamson
                        • 175
                        hose box said vacuum...
                        will keep looking. I've been to pep boys, adavnced auto parts, checkers...guess I better check napa too.
                        • Geezer
                          • May 2003
                          • 2985
                          For what it's worth Honda uses the same size hose on their vacuume petcocks. I had some left over from replacing the advance hose on my bike and I used it on a customer's GL500.
                          Geezer
                          • CWilliamson
                            • 175
                            Hmmm...and here I sold my old cx500 to a friend...he wouldn't miss those lines would he... ;-)
