EBC rotors
  • dorkbme
    • Mar 2006
    • 6
    EBC rotors
    Hi all:
    I have a '78 XS that I bought new and it has been basically sitting for the past 20 some years.
    With a new battery, fresh oil and gas it fired right up, so I am in the process of getting it road worthy again.
    I am rebuilding the master cylinders and putting new rotors on it and I am wondering if anyone would know EBC's part number for the rear rotor.
    I sent EBC an e-mail but have received no response. One place told me the rear rotor is a MD 2025 and another said it uses a MD2024.
    Anyone know the correct rear rotor for a '78?
    Thanks and it's good to see there are quite a few 11's still out there.
    • 7817
    The three rotors on the '78 are all the same part number. Whatever they say for the fron, put on the rear.
    Ray
    • dorkbme
      • Mar 2006
      • 6
      Thanks for the quick reply.
      Mark
        Hey there Dorkbme,
        Like DiverRay says, they are supposed to be all the same. According to the EBC product catalog, they list the front rotors as:
        MD2024RS and MD2024LS for right and left side, AND they list the
        MD2025 as the rear rotor!?
        Their rotors are drilled with the swirling hole pattern, and so that's why they recommend the left and right side differentiation, however, a few folks have commented about the 80-82 series OEM slotted rotors, and have mounted the alleged right side style on the left and vice versa with NO ILL EFFECTS!!
        Back when the bikes first came out, Yamaha made a differentiation in the pad kits for the front vs. rear on the 78E and other standards, supposedly a different material is used/needed for the rear vs. the front.
        Now, EBC also makes brake pads, and their catalog lists the SAME pad # for the 78E front and rear, so not sure why they would need to list a different ROTOR for the rear vs. the front, vs. just saying put the Front Right Rotor on the rear??
        After all of this, WHY are you wanting to spend this kind of $$ on new EBC rotors, vs. either getting NOS/used from EBAY, or just cleaning up yours? I had some with a little layer of rust on them, and just took a wire brush on a drill and cleaned it off. Also, just repainted the center spokes, and they looked and worked just fine!
        • dorkbme
          • Mar 2006
          • 6
          Thanks for the reply, Top Cat.
          Only reason I am replacing all the rotors is because I can.<BG>
          I have a Road Star that I have customized about as far as I want, and I had a friend that said I should get my 11 running. So, not being one to leave well enough alone.........
          I was told the MD2025 is about a 1 1/4" smaller in diameter than the stock rear rotor on a '78, so that's why I was hoping someone could tell me for sure that the MD 2024 would be the correct one.
          As far as running a front rotor on the rear, I thought of that too. The rear rotor is thicker than the front, so didn't pursue that angle any farther.
          Thanks again,
          Mark
            Hey Mark,
            I just went out and remeasured my 79SF and 81SH, and ALL of the rotors are the same ~11 & 5/8" diameter size, and both front and rear are about 7.00 mm thick, manual says should be thicker than 6.5mm, both F & R. So...I would get 2 of the 2024RS, and one 2024LS, and not the 2025.
            BTW, if your old rotors are in otherwise good shape, I'm sure there are several folks here that could use them!
            Well, since $$ is no object, don't forget the SS brake lines! You can get colored ones to match a paint scheme from HEL USA!! I just got a set, they look great and perform great!
            Okay, you know you have to post photos of your finished restore/reburbish when you're done!!
            • dorkbme
              • Mar 2006
              • 6
              Top Cat:
              Thanks for the heads up on the brake lines. I was planning on replacing them, but didn't know where to look.
              I'm guessing that the 2025 is for an '82 1100.
              My frame is at the powdercoaters right now. I'm having it powdered a "rich gray", and painting the bike a pearl silver. Sometimes I'm not real fast, or maybe it's too many irons in the fire, so it might be a while before I have it back together for pics.<BG>
              Thanks again,
              Mark
              • AKMac
                • Sep 2005
                • 141
                • Utah
                I've got a set of three EBC rotors here, and Top cat is right. You'll want the 2024's.
                1979 XS1100 Special (Chrome Queen)
                • dorkbme
                  • Mar 2006
                  • 6
                  Thanks, AKMac.
                  So, do I want the MD2024 with no suffix, or do I want a MD2024RS for the rear, which is the same as the right front?
                  Thanks again for the help.
                  Mark
                  • AKMac
                    • Sep 2005
                    • 141
                    • Utah
                    You'll want one MD2024 (left side), and two MD2024RS (one is for the rear). Hope that helps.
                    • dorkbme
                      • Mar 2006
                      • 6
                      Thanks.
                      Will call them back Monday and get the right rotor.
                      Take care,
                      Mark
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        Are these the solid rotors that look like stock or the $200 ea. full-floating rotors?
                        Pat Kelly
                        <p-lkelly@sbcglobal.net>
                        1978 XS1100E (The Force)
                        1980 XS1100LG (The Dark Side)
                        1999 Suburban (The Ship)
                        1994 Dodge Spirit (Son #1)
                        1968 F100 (Valentine)
                          Hey Pat,
                          They are their multipiece floating rotors, but their's are mounted with secure RIVETS.
                          EBC Pro-Lite Fully Floating SPORT replacement front rotors
                          Complete “Hub and Rotor” units for direct bolt-on
                          Assembled with sturdy RIVETS not risky circlip systems
                          Disc rings made from roll forged BILLET STEEL offering 18% more stopping power than stainless steel but with the high strength of steel ... better braking and NO RISK of cracking as with cast iron rotors
                          Lightweight forged alloy centre hub using special high strength ductile mill rolled aluminium alloy, coloured either silver or gold to match bike cosmetics
                          Pro-Lite discs resist distortion longer PLUS the unique “Birdswing” drill pattern prevents ridges developing on the rotor.
