valve cover torque specs?
  • Bauer
    • 269
    • Garrison ND
    Does anybody know off hand what the 80SG valve cover bolts are to be torqued too? Just put a new gasket in and am polishing the cover. Need to know what to torque to when I go to put it back together this weekend.
    Thanks.
    Bauer
    1980 XS 1100 SG (The 3rd Degree) - The Cafe' Racer
    Image Photos @ http://photobucket.com/albums/f230/BauersXS11/
    1980 XS1100 G (The Trouble Maker)
    Fully stock and still goin at 65k miles
  • GNEPIG
    • Apr 2005
    • 1647
    • fl
    .. 85 to 110 inch lbs.. INCH lbs not foot lbs
    • Winterhawk
      • Jun 2004
      • 684
      • Missouri
      7.2 ft. lbs.
      • DeanR
        • Jan 2005
        • 1486
        • Finger Lakes NY
        I just snugged mine up pretty well. Don't have a torque wrench. Was told it doesn't matter much for the valve cover. Opinions?
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • xssiveone
          • 766
          • Windsor,Ontario,Canada
          I think it's important to tighten it uniformly so it doesn't twist or warp.
          Also, check the bolts after a period of time, say a few weeks or a month. Don't know if I'm the only one, but about a month after I did my valve adjustment, I had one of those "where the h@!! is all this oil coming from??!!" moments. My cover bolts had loosened off... and I used a torque wrench on them as well. After I retightened them, it's been 2 seasons and so far no leaks this time.
          Brian
          remembering the same thing!
          • AKMac
            • Sep 2005
            • 141
            • Utah
            Is there a special pattern to use?
            1979 XS1100 Special (Chrome Queen)
            • Bauer
              • 269
              • Garrison ND
              qood question AKMac
              Does the clymers manual show torque and pattern specs? I dont have mine here.
              Bauer
                Getting torqued over the valve cover!
                The service manual does NOT recommend any particular torquing pattern for the valve cover bolts, but I always start in the middle closest to the cam chain well, and work my way outwards. Like Brian said, after a few rides where the gasket and engine have had a chance to warm up and cool back down, the gasket will shrink a little, so a retorquing is recommended!
                  One of the more common torque values for anything on the engine is 7 ft.lbs, and follow TC's advice on the pattern. Starting in the middle, and working outward will force any distortion to the ends of the valve cover. Just like an oil pan or valve cover gasket on a car.
