clutch replacement
  • bandet01
    • 698
    • connersville indiana
    clutch replacement
    ok guy i am getting ready to replace my clutch and i was woundering what is a good strong clutch for drag racing i need to get as much power to the ground as i can but i still want to be able to ride it on the street. so what company would you buy a good clutch from
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
  • John
    • 5117
    Barnett seems to be a popular brand. Maybe slip an extra steel plate into the stack, if there is enough space. That seems to help slipping clutches, so it may help to lock up a new one even stronger.? I don't race, but after doing a big bore, I went with a brand called Factory, for my clutch. I replaced the springs also. I haven't had any slippage problems when twisting it up ( blowing the carbon out) every now and then.
      New Clutches, a Sticky Situation!?
      I could have sworn that I had read where someone had used the Barnett clutch plates, but that they had a tendency to stick too much, and they had trouble disengaging the clutch!? This could make it a bit more difficult handling it on the street, slow corners and traffic where slipping the clutch is actually needed!?
      Other brands are Vesrah, and EBC, don't know what the GENERIC ones on PartsNMore are? I got a set from JCW 5 years ago, but I abused them a bit with Xsive slipping in very hot weather! I'll be pulling them out to check their spec measurements, and I'll be slipping an extra Steel in the pack in any situation!
      Bandet, try a search on here for Barnett Clutch and see what you find?
      • GNEPIG
        • Apr 2005
        • 1657
        • fl
        .. i have used the Barnett clutches before and they started slipping within 2000 miles, its been awhile since i have used them, they might be better by now but i won't go out of my way to use that brand anymore. now i use the EBC's, they seem to be holding up to the abuse pretty good. and if you're racing, the stiffer springs are a must and dont use the synthetic oils.. Bike Bandit sells them both and the price is pretty good = low. i think the price was less than $90 bucks shipped for both
        .. not the last word, just one @ssholes opinion from expeirance
        • 81xsproject
          • 3185
          • Fortuna, CA
          I did the referbish on mine and it worked great. No more slip
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
            Barnett site:
            Friction Steels Springs
            1978-81 XS1100 YPK-5(8) YP-20-20(7) MT-45-6
            On MAW site:
            (27392) $91.95 Barnett Kevlar Friction Plates (7) #YPK-5 Mfg.#: YPK5
            But this lists the kit with only 7 plates?
            • bandet01
              • 698
              ok i am looking at the ones at dennis kirk has anybody used this brand that they sell it is Vesrah Clutch Discs and the price is 102 and the have the Vesrah Heavy-Duty Clutch Spring Kit for 12 but i am wopundering if anybody has used this setup and how well it has held up
              and what kind of special tools will i need to change out the clutch
                • 7818
                bandit01,
                I picked up the springs and plates from Bikebandit. I think the plates are Vesra, and the springs are "heavy duty". I ended up only installing the springs, as my plates were well within specs. I've put about 3K miles on the clutch, and just yesterday had the front end come up, and NOT trying too.
                The heavy duty springs are the #1, and if you read through the old clutch thread, you'll find almost any clutch plate should be good. The Barnett Kevlar plates my be the best for drag racing, as they should grab once the start to warm up.
                Just my thoughts...
                Ray
                • chevy45412001
                  • Mar 2003
                  • 1412
                  • Jacksonville Florida
                  XStra steel
                  i've been running XStra steel plate for a few years now. seems to have taken the small slip i had put. used to once in awhile slip in high when i would giver.Not since though.
                  1982 XJ 1100
                  • bandet01
                    • 698
                    no special tools need to change out the clucth just the book and just regular hand tools i mean i only plan on changing out the friction disc and the springs
                    • mro
                      • Oct 2005
                      • 4276
                      • Hayward, California
                      XStra steel
                      read several times about putting an extra steel plate in clutch.
                      Don't recall extra friction mentioned.
                      Where you guys putting the extra plate???
                      mro
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        no special tools need to change out the clutch
                        Not necessarily true... You ShOULD have a torque wrench, a 27mm socket, and if that big nut is anything like mine, a tourch and one hell of a breaker bar.
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • bandet01
                          • 698
                          ok thanks and all that is stuff i got in my tool box
                          i think they just double stack a extra steel in there to take up space
                            Hey Mike,
                            The "tech tip" suggests placing it in the middle of the pack, just 2 steels next to each other, and then all of the other friction and steels alternated as usual!
