79sf carb floats
  • Yamaniac
    • Jul 2005
    • 262
    • Stilwell, KS
    79sf carb floats
    I had one float chamber caved in. put some heat on it and melted solder (detached chamber from arm). Also tried to boil it out(in water) to no avail. I'm gonna try to pop the chamber apart, back out and then re-solder, but thought I'd check to see where I might be able to get a replacement if'n I screw the chamber up worse than it already is.
    MikesXS floats
    The brass floats MikesXS sells have a part# 256-14985-00-00 (for a 38mm carb)
    The part # for an SF is 2a2-14985-00-00
    I don't know how to tell if it will work as a replacement or not. Any help?
    After doing some searching on here, I haven't been able to find any other fix it method, or any other place to buy the float. I would prefer not to replace all four to the plastic floats before finding out what all my options are.
    Thanks
    Theron
    Yamaniac
    '79 xs11 sf - WidowMaker, 750 final drive
    '80 xs1100 sg- ENEMY#1 parts bike no title(free)
    '79 f- frame and swingarm (and title)
    '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
    '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
    Able to Float Your Boat!
    The Float is still available from Yamaha and Bike Bandit :
    part . . . . . BB#. . . . . . . Price/Each
    25: FLOAT 20736-001 $22.53
    • Yamaniac
      • Jul 2005
      • 262
      • Stilwell, KS
      thanks TC
      a little off thread here, but where did you find/make/etc your extended front forks on Godzilla? What is involved with extending them?
      BTW, how did you figure out the Yamaha still carried those floats? I'm guessing you called up your local dealer?? The online parts deal just lets me add to wish list and doesn't give me a price for anything, so that's why I'm curious.
      Thanks again
      Theron
      Yamaniac
      • John
        • 5117
        You'll need to order from Bikebandit. You can't order from the Yamaha site.
        • Yamaniac
          • Jul 2005
          • 262
          • Stilwell, KS
          Knew I couldn't order from the the yama site... it said to see a dealer for price and availability... That is no good? I was trying to NOT order from bike bandit, but looks like the way to go...
          thanks, John.
          Theron
          Yamaniac
            It's nice to get Forked Over by Frank!
            Hey Theron,
            First of all, I use this site with the OEM Yamaha Parts #'s to verify whether it's still available from Yamaha, and I also get a fair price quote as well. Problem is this site has a $100.00 minimum order limit, so I haven't ordered anything from them!
            Then I went to BB, and checked the OEM parts to see what price they quote, knowing that it SHOULD be listed amongst their parts vs. being "Discontinued"!
            Now, as for the front forks, after a bad front ender with a Cager I was able to get them from Forking by Frank . They are a simple bolt on fit. You provide the model make year and He makes them complete with the proper threading for end caps, etc.! IIRC, they even provided teh 4" spacers needed since they were 4" over, so the OEM springs work just fine!
            Dale Hicks...IIRC recently put on 6" overs on his Special, I remember posting photos a while back, you can try doing a search for 6" over length forks! He got them from FbF, around $200.00 or so, nice fresh clean chrome!!!
            Here's the thread with the photos...however looks like PHotodump might be down for now, the photos aren't showing up, and I know I didn't Delete them!?
            Highlander's 6" front forks and Mine
            • Yamaniac
              • Jul 2005
              • 262
              • Stilwell, KS
              OUTFORKINGSTANDING
              Thanks for the great info. I have a spare frame sitting here and I started getting some wild ideas...trying to stretch the frame a little and change angle of the neck to accept some longer forks and get a little rake on it.. But why mess with perfection?
              Sometimes I hallucinate. I think someone put acid in my grilled cheese sandwiches.
              Thanks for the info, regardless.
              Theron
              Yamaniac
