I had one float chamber caved in. put some heat on it and melted solder (detached chamber from arm). Also tried to boil it out(in water) to no avail. I'm gonna try to pop the chamber apart, back out and then re-solder, but thought I'd check to see where I might be able to get a replacement if'n I screw the chamber up worse than it already is.
MikesXS floats
The brass floats MikesXS sells have a part# 256-14985-00-00 (for a 38mm carb)
The part # for an SF is 2a2-14985-00-00
I don't know how to tell if it will work as a replacement or not. Any help?
After doing some searching on here, I haven't been able to find any other fix it method, or any other place to buy the float. I would prefer not to replace all four to the plastic floats before finding out what all my options are.
Thanks
Theron
MikesXS floats
Thanks
Theron
I was able to get them from
