I'm going to look at a midnite special XS1100 tomorrow. What are some soft spots of the bike I should check on? Right now its got a locked front brake and its not starting due to flooding, the owner said he will have those fixed before I come look at it. He says its an 82.
looking at a XS1100 midnite, might buy
Tags: None
(stole that one from I-dont-know-who) -
IT's a GAS, GAS, GAS!!!
Hey there Gas,
Can't tell WHERE you are, no info in your profile, so don't know if you're in the US, Canada, across the pond??
If US, then IF it's an 82, it's an XJ, not an XS11. IF it has curved spoke wheels, it's an XJ, along with other tell tale signs, like YICS on the engine covers, etc.
Otherwise it's an 81LH, that probably first got registered/titled in 82. However, I've heard that Yamaha made the XS in 82 in Canada and EURO!?
The flooding is probably gummed up carb float needle seats. Not a biggie persae` cause you'll need to rebuild the carbs anyways. What is a concern is ensuring that gas didn't leak into the intakes and get down into the engine, not good to run it with gas in the oil!
You say locked front brake...as in ONE? The XJ's front master cylinder controls the right front caliper, the rear brake lever controls the rear and the left front thru a linked system! Starting to sound more like an 82XJ1100.
Good Luck! T.C.T. C. Gresham
Yeah, sorry, I'm in GA. He said he rode it up till the summer, let it sit the winter, then pulled it out to sell it and it was flooding and the brake was locked up.
But what you're saying is an XS1100 would have 2 front discs and calipers and a XJ would have 1? If thats so its a XJ. It only had one and he had it off as his mechanic was working on the caliper.Comment
Nope.... got that backwards. If it has 2 front calipers... it's an XJ.Try your hardest to be the kind of person your dog thinks you are.
Nope on both accounts
Both the XJ and the XS has dual front disc calipers, but the XJ's front MC handlebar only controls the right one, the rear MC controls both the rear and the left front caliper.
The XS11 has a larger capacity front MC that controls both front calipers. So...if it has only 1 front caliper, then either the "other" one was removed, OR it's not an 11?
T.C.T. C. Gresham
Hey TC
The '81 LH has "curved" gold-spoke wheels. The '80 LG has straight gold-spoke wheels.
And at least my '81 LH has the split-controll calipers on the front - hence the reason the Midnight Special front master cylinder is much smaller - it only controls one brake caliper.
BrianComment
curved spoked wheels, it did have dual front discs, I missed that the first time. I doubt I"ll buy it though, it still won't start, it has fuel and ignition issues, and I looked some more and realized its been dropped at one point in its life. It also has 31k+ miles. Seems like he's hiding something, he's acting real shady.Comment
Easy way to tell the XJ from the XS at a glance is the instrument cluster. The XJ has an LCD readout panel between the tach and speedometer. Wheels / rims are interchangeable, not always the most reliable indicator, but the instrument panels are completely different and won't interchange. The XJ also has square handlebars, another good tip-off.
There was an XJ Midnight Special; I've never seen one but a few people have reported seeing one. If this is a "Midnight Maxim" I might be interested in it if you are not; let me know.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy StrutComment
Compression tests are quick and easy. It would tell you a hell of a lot into the amount of "fixing up" that it MIGHT need.
Originally posted by gasisontheright
curved spoked wheels, it did have dual front discs, I missed that the first time. I doubt I"ll buy it though, it still won't start, it has fuel and ignition issues, and I looked some more and realized its been dropped at one point in its life. It also has 31k+ miles. Seems like he's hiding something, he's acting real shady.Skids (Sid Hansen)
Hey Brian,
Thanks, I had forgotten about the 81LH having the curved spokes, and that it was where Yamaha started with the split front brakes, 'preciate the correcto!!
Hey Gas,
Well, he might be trying to hide something, or he may just not know what's really wrong with it, and as has been found by many here, lots of times, it's a relatively simple fix once you know what to do, and have a little mech skill!?
What some folks think are really bad problems quite often turn out to be easy fixes, like corroded connectors that can cause an ignition problem. The leaking fuel is easy to fix. Even the dreaded 2nd gear problem isn't that hard to do.
With these problems presenting themselves, you should be able to do a bit of bargaining to get the selling price down a bit!
T.C.T. C. Gresham
I talked to him today. He said it turned out he didn't have enough gas in it. He got it running, took it out for a ride, then it broke down on him. He said something ab out the fuse box, he thinks its like a loose wire or something, but he knows very little about bikes/motors, and it tired of calling mechanics so he said he'd let it go for $700. I'll probably end up with it tomorrow.
What a block head, the seller that is!
Well, it just so happens that I have those nice new ATC/ATO style replacement fuse blocks in stock and ready for immediate shipping up receipt of a modest $7.00 payment!
See the thread here, and follow the instructions! Now, don't forget to show us some photos of your new ride!!
T.C.T. C. Gresham
Nice work... I went to Georgia and bought my MS..It's an '81. Get some pictures posted!!!!!!!!!!!!!"If A equals success, then the formula is: A = X + Y + Z. X is work. Y is play. Z is keep your mouth shut." - Albert Einstein
1980 LG
1981 LHComment
Thanks all who helped.
