will MikesXS controls work
  • AKMac
    • Sep 2005
    • 141
    • Utah
    Does anyone know if the "Bar Switch Assembly" Part #24-2059 and Part #24-2060 sold by MikesXS will work for our XS11's? They look identical in the pictures, plus they are avaliable in chrome.
    1979 XS1100 Special (Chrome Queen)
  • Street_Rat78
    • Sep 2005
    • 253
    • Columbia, SC
    I am also interested in the answer to this question. Who on here is our "Mike's XS guru"???
    ~ Street Rat ~
    Mitch
    '78 XS1100 "My Mistress"
    Knowledge is Experience. Everything else is just Information
    • bulleteer
      • Dec 2005
      • 7
      • greenville, ny
      I've been told that the 650, 750, 850, 1100 and even the 400 all share the same controls. I'm redoing an 850 and plan on buying them. fyi, Jon
      • switz1
        • Feb 2007
        • 70
        • Bushnell, IL.
        Update
        Anyone get definate yes it fits?
        1978 1100E Standard
        2 1985 700 Maxim's (black & red)
        1986 600 Radian (basket case)
        1979? GS1000 (no title)
        1980 1100SG Special
        • red bandit
          • 950
          • central michigan
          AKMAC.... I love your name!!
          79 SF parts bike.
            Re: Update
            Hey Switz,
            If you'll do a search for chrome Goodness and AKMAC you should find his posts, and see his photos of his machine WITH the chrome controls mounted. They will mount, but I don't know what difference the electrical plugs have or what he may have had to do to swap wires in the plugs to get the controls to work!?
            • AKMac
              • Sep 2005
              • 141
              • Utah
              In short, yes they will work but your going to need to do some wiring to get them to work.
              The right side controls were very easy. You just have to wire in connections then proceed to connect red to red, black to black, etc.
              The left side took a while. Since I didn't have wiring diagrams of a XS650 I opted to wire single connectors to each wire. That way if I screwed up I could just reverse or swap wires. If you keep blowing a fuse for your headlight, you did something wrong It took me a while (and some fuses!) to figure out the mess but now everything works perfectly.
              They are quality units and I would recommend them to anyone looking for some more bling
              • 81xsproject
                • 3185
                • Fortuna, CA
                Oh come on, AKMac! Like you need MORE bling
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • Jason Youn
                  • Nov 2009
                  • 4
                  • Phoenix, AZ
                  Would you be able to give us some info on how tow wire these things up?
                  Some photos would be great!
                  Thanks,
                  • xs11bobber
                    • Jun 2009
                    • 229
                    • Cromwell, Indiana
                    Yes. It can be done. I have the right installed now. It's cake.
                    The left, I have and have done plenty of research and it can be done as well, but it needs a bit more "help" hooking up. It's all a simple trace of what each color does in the controls vs. each color on your harness compared to your clymers. HTH. Let me know if you need more details. I can get the left controls figured out quick and take some pics if you need. Can take pics of the right side also if need be, but that one can be explained.
                    Josh Yoquelet -- I'm having dreams of my XS
                    '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
                    '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
                    '81 Air forks w/23,000 miles
                    New steering head races and bearings
                    '78/'79 standard wire harness
                    Drag bars, w/Mikes controls
                    T.C.'s fuse block
                    PNM Coils
                    7mm Dyna Wires
                    NGK Resistor Caps
                    Custom 1" clutch and 9/16" MC
                    http://xs11bobber.tripod.com
                    • TomRodgers
                      • Jun 2008
                      • 492
                      • La Porte Indiana
                      IIRC, the left side had the issue with not having a "hazard" switch on it. Dont know for certain, but when i purchased my new M/C for 'Sunshine, i asked Mike Lalonde ( THE dude at MikesXS) if it would fit. As others have stated, he seems to have a distaste for the 1100, but oh well.... he said they didnt have the hazard switch on the bottom, so the wiring will be a bit different. If 'Bobber' and others have figured it out, we can all 'patiently' wait for them to post photos and detailed instructions on how it works!!
                      I know that my controls will need to be replaced soon (cosmetic reasons only.....for now) and i myself would like to know how to do it also!!!! My $.02
                      4:1 Jardine w/ headerwrap
                      Windjammer(wiring issues)
                      New paint/brakes to come!!
                      '80G FrankenBike (parts bike)
                      '80G to fix "BlackSunshine"
                      Stock Pilots/125 mains
                      Pod filters; 4:1 Kerker??
                      SS Brake lines w/ new M/C's
                      LED Brake Lite
                      Needs paint....
                      • devilschld
                        • Aug 2008
                        • 174
                        • kansas
                        dude u have to do something with the eye catcher
                        1980 xs1100 sg.
                        • TomRodgers
                          • Jun 2008
                          • 492
                          • La Porte Indiana
                          Like what?
                          LED Brake Lite
                          Needs paint....
                            I recommend you get a grip.
                            I meant new grips for the bike...to take your mind off of the Avitar.
                            • foreda
                              • 949
                              • Southwest Louisiana
                              Distractions
                              I just love distractions!!!!!!!!!!!!!!!!!!!!!!
                              78 XS1100E Standard
                              Coca Cola Red
                              Hooker Headers
                              http://i408.photobucket.com/albums/p...m/DSC00580.jpg
                              1979 XS1100 Special
                              http://i408.photobucket.com/albums/p...m/DSC00612.jpg
                              1980 XS Standard
                              http://i408.photobucket.com/albums/p...m/DSC01137.jpg
                              2006 Roadstar Warrior
                              http://i408.photobucket.com/albums/p...um/warrior.jpg
