Headlight question
  • jimboreeno
    • 427
    • Smithville, MO
    Headlight question
    I just changed out my steering head bearings and my fork seals. Obviously I had the entire front end apart and the dash and light off. When I put it all back together...everything is great except the headlight doesn't work, including the highbeam indicator?! I put the voltage meter on it and randomly got no, and then wavering low, voltage. I have to wonder if I grounded something out or what? I wanted to get some input before I took the dash apart to look for a broken wire.
    JimBoReeno
    My Ex!"Half-Breed"
    '82 XJ1100 Maxim with
    '80 XS1100SG Motor
    Current Bike
    2000 Indian Chief
    Millennium Edition
    I just went through this yesterday. No idea why I was getting some voltage, but ended up being a fuse for the headlight. It came apart in my hand.. so I wired it up for a buss fuse... ended up having no dash info then. Ended up having to do them all. Once I opened the fuse box and tried to close it... nothing had good contact again until i got this done. Here is a link to the "Poor boy" fuse fix.
    Fuse Fix
    • jimboreeno
      • 427
      • Smithville, MO
      I had grounded a wire! I took the headlight bucket off and found the wire to the highbeam indicator had a stripped side. It had grounded out causing the whole deal to go out. I put some electrical tape on it and VOILA! I have light.
      JimBoReeno
      My Ex!"Half-Breed"
      '80 XS1100SG Motor
      Current Bike
      2000 Indian Chief
      Millennium Edition
        • 5057
        You killed the gremlin!!! Good going.
