Low fuel light
  • wingnut
    • 695
    • NC
    Low fuel light
    I'm putting the fuel tank on the special for the first time . The PO had cleaned and sealed it so when I got the bike the tank was apart, no fuel valves installed and the sending unit plate was also off. Cleaned the mating surfaces, installed the plate and rebuilt the fuel valves. The tank is bone dry so when I hook up the connection to the low level light I expected to see the light come on. It didn't. Jumped the connection on the bike side and it lights up. Messured the resistance across the sender and it reads 1.79 ohms. Bad sender? Searched the site but came up empty. Wireing diagram in manual is no help. Nothing should work if its wired like it shows. Ideas?
    wingnut
    81 SH (Daily Ride)
    81 XS 400
    Thomas Jefferson
    My Clymers manual says to remove the sender from the tank, and test the green and black wires at the sender, not at the plug. With the ohmmeter on the Rx100 scale, it should read 1500 plus or minus 100 ohms @77 degrees F
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      "Not too Level-headed"
      I can't give you the specs, but once I... no wait... it was someone else, not me... uhmm.. someone put the fuel sending unit in the tank upside down-facing the wrong way. Took me... I mean him... a while to figure out why the tank read full on empty and empty on full. Don't know if it's possable to do on a Special, but it is on a Standard. May explain why the light didn't go on with an empty tank.
        Hey Prom,
        The Special's only have an ON/OFF type sender(idiot lite), no rising float mechanism to get turned upside down. It's a rheostat type "I think", and as long as the fuel covers up the coils, they stay cool, but once the fuel gets low, the coils are exposed, allowing them to heat up. This heat bends a ?tang? that makes contact sending the signal to the "Lite" giving you the......
        EVIL RED EYE that lets you know you better start looking for a station within 10-20 miles, or you'll be pushing this beast a while!
        • Dragonrider
          • 1219
          • Garland, Texas
          The fuel light sensor is slow to respond too...if your just clicking the bike on and expecting to see it, then turning it off cause it's not on...
          It may take it a minute or two...
          CUAgain,
          Daniel Meyer
          • prometheus578
            • Aug 2004
            • 4012
            • Olympia , Wa.
            Damned Japanese engineers..."
            (25 years in the past... some technical weasle tries to justify his paycheck)
            "Today... I'm going to reinvent the fuel gauge. People will praise my honorable name. And sometime in the distant future... some poor fool who doesn't have a life will be sitting at his computer... cursing the day I was born for making him look like a fool."
            Bah! I don't need some low-grade Japanese engineering student to make a fool out of me... I do pretty well on my own.
