Hey Firehawk,
Your mileage is about PAR for this machine! As for your carbs, was concerned about whether you had dunked or soaked the bodies in carb cleaner?? You could have damaged the butterfly seals, causing vacuum leaks, which could contribute to difficulty starting, but sounds more like the float bowl and fuel enrichener jet being clogged in the bowl!!
As to your petcocks, fuel should only come out of one petcock at a time, since you had it coming out of both, then your petcock rubber gasket/valve is probably damaged, and they need to be rebuilt. It would be best NOT to use RESERVE, cause you could run out and then wouldn't HAVE a reserve. Just plug the OTher spout, and use PRIME...it's not Primary. Prime on Specials is designed to bypass the OCTOPUS and send fuel directly to the bowls, cause after sitting a while, they could possibly be a bit DRY due to evaporation, and so this ensures fuel gets to the bowls without the need for engine vacuum actuating the Octy valve when using RUN!
I started this reply before thinking to check the whole thread, do you have the Octopus. It might also NOT be working properly, and you might be better off just bypassing it entirely, just turn the gas off at the petcock when you stop/park to keep it from leaking thru the carbs.....IF the float needle valve doesn't fully seal/seat!
