Revised Opinion!
Hey Firehawk,
I agree, I think it looks fine!! Now, I ran 4-1 headers with stock airbox for 7 years WITHOUT rejetting, and never had a meltdown or problems with the pistons. With your good colored plugs, you probably don't need to rejet, but are these NEW plugs that you have checked, or were they in there before the pipe swap?!
As to your symptoms, with it dropping rpm, I'm now more in agreement with Danny in that it sounds like the PU coil wires now, like Danny said, due to the increased rotation of the assembly while in second gear causing an intermittent break in the wires which cuts out the signal to the TCI until the engine either changes rpm, or vacuum changes, both changing the rotation of the PU coil plate and causing the wires to reconnect.
The 81 doesn't have "mechanical" centrifugal advance...it's incorporated in the TCI, but it does have vacuum. FIREHAWK, pull and plug the hose from the #2 carb that goes to the vacuum advance, and then try riding the bike and see if you notice the symptoms in the same rpm range as before. IF it doesn't do it, then reconnect the hose, and IF the symptoms recur, then you've pretty much proved that it's the PU coil wires. The 81 isn't as likely to develop this problem but it's not immune since the plate and wires still flex with the vacuum advance.
Sorry Ken and Danny, but I don't drink beer
 never acquired a taste for it....too strong of a sweet tooth!
  However I have straight shot J.D. ..
   go figure!?
					Hey Firehawk,
   go figure!?
