Cranking RPM
  • mainlylinux
    • 211
    • Michigan
    Cranking RPM
    Can anyone tell me what the approximate cranking rpm should be of an XS11 with a healthy battery?
    Thx,
    Dan
    Home of ENIAC
    Kinda like a MANIAC with 2 letters difference & a computer on board
  • bandet01
    • 698
    • connersville indiana
    i aint got a clue but when i was working on my bros bike the start didnt spin that fast so i would say 500 rpm or less i think it has alot of other things to deal with when starting a bike then just the cranking rpm like fuel spark and compression too
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
    • LoserShoes
      • Apr 2005
      • 524
      • Bangor Maine
      Hook your scope up to the pickup coil, crank it, and get the milliseconds from leading edge to leading edge. That gives you secs/rev. Divide 1/(sec/rev) = revs/sec. 60 * revs/sec = rpm.
      Don't know how much math you know, so there it is.
      Steve
      73 Yamaha DT3 - DirtyHairy
      CZ 400 MX'er
      68 Ducati Scrambler
      RC Planes and Helis
      • mainlylinux
        • 211
        • Michigan
        Bike's 27 miles from the scope :-)
        I did get a schmitt trigger hooked up the other day to the pickup coil output - and it works. But, I doubt it will work if I slow the rpm's down to cranking speed. I think the wave form will be to weak to trigger the schmitt trigger.
        Looking to amplify the signal now - just trying to make it as easy and painless as possible.
        Luckily I got a whole bunch of circuit boards from a client of mine filled up with all kinds of goodies!!
        Dan
        Home of ENIAC
        • mainlylinux
          • 211
          • Michigan
          On that note, anyone know of a device to amplify and create a nice square wave, all in one package, with minimum # of pins for a tiny outlay of $$$?
          Dan
          Home of ENIAC
          • JWSanders
            • 879
            • White House, TN
            555 timer circuit is exactly what you're looking for, I believe.
            Easy to use, requires a very small footprint circuit to drive it. Very reliable, too. Could be encased in epoxy and last forever.
            100mA output, I believe. I'd bet there are higher powered versions, too. This thing's been around forever.
            80 XS1100SG
            81 XS400SH
            Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
            A Few Animations I've Made
            • deeparchae
              • Jan 2006
              • 6
              • Golden CO
              I'm not sure this would work, but you could loop the signal through a op amp ( quad if needed) and boost it that way. Might get noise though.
              • mro
                • 4276
                • Hayward, California
                Cranking RPM?
                If you still need cranking rpm, I'll bring home my tacks from work and find out. (got a remote digital and a neat little tack that you can just press against a shaft)
                mro
                • LoserShoes
                  • Apr 2005
                  • 524
                  • Bangor Maine
                  Look into a zero crossing detector, usually built with a comparator, but can be done with an opamp, LM358 for single voltage automotive type apps.
                  Steve
                  CZ 400 MX'er
                  68 Ducati Scrambler
                  RC Planes and Helis
                  • mainlylinux
                    • 211
                    • Michigan
                    Yes, if you can bring home your tach and get the info that would be great.
                    I'll check into the circuits you guys metioned.
                    I just picked up a gear reduced dc motor today from work, so hopefull that will get me close to the cranking rpm.
                    Dan
                    Home of ENIAC
                    • JWSanders
                      • 879
                      • White House, TN
                      Looking further, this seems to have the best description of how to make a Astable Oscillator (Square Wave Generator). Really descriptive.
                      80 XS1100SG
                      81 XS400SH
                      • mainlylinux
                        • 211
                        • Michigan
                        ttt
                        Home of ENIAC
                        • mro
                          • 4276
                          Sorry
                          forgot to check cranky rpm
                          try to remember tomorrow and post when I get home
                          wrote myself a note
                          mro
                          • mro
                            • 4276
                            Cranking RPM
                            190 to 200 rpm
                            Don't know if my 80G is a good overall sample for the XSs.
                            Nothing to compare to yet.
                            Just under 17K miles and no problem starting.
                            mro
