K & N Air Filter
  • Never2L84Ridin
    • 84
    • Northeast, KS
    K & N Air Filter
    Has anyone used the K & N air filter YA-1400, to replace their stock air filter? Just curious if it helped with performance. What was the cost? Called O'reilys and they have to send off for a price and filter will have to be special orderd. How does this compare to the pod filters.
    Thanks,
    Kevin
    "Watchout for the guy behind the guy in front of you"
    1980 XS 1100 SG
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Mine was about $35. Not sure about more power but easy to clean (I run it through the dishwasher when SWMOBs not home) and won't have to replace it.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
      I replaced the filter in Daily Ride with a K&N. I like it because it is perminent, and easy to clean. I don't have a SWMBO, or a dishwasher, so I just use the sink and HOT water to clean.
      I put the filter in while preping the bike, so I can't compare to the old filter. I do get about 38mpg on my commute, and that is at speeds up to 90mph.
      Ray
      • 81xsproject
        • 3185
        • Fortuna, CA
        I had one on my bike before I pulled the airbox. It plus the 4-1 blued my pipes, so you might go up a main jet size to compensate?
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • Lamric
          XStremely XSive(Deceased)
          • 410
          • Kenley, Surrey, England
          Hi Kevin,
          I put a K&N filter in my LG (same engine as your SG) the carbs had the original jets in and I run a 4 into 2 exhaust, I didn't have to rejet. Maybe I was lucky though.
          The bike 'sounds faster' and I think it is but I couldn't prove it.
          They work for me, I plan to fit put a K&N in my SG now.
          Brian
          XS1100 LG "Mr T", SG "ICBM" & FJ1200
          Check out the XS Part Number Finder
          Be not stingy in what costs nothing as courtesy, counsel and countenance.
