Got Any Nuts???
    • 7712
    Jack, I would look at the threads in the head, and run a tap to make sure they are good. Then go ahead and install the stud/nuts, and soak the nuts in penetrating oil. after a day or two, try to pull the nuts once again. You can use permatex stud mount when you install. once they are in, let set for a day and try to remove just the nuts.
    Ray
    • LoserShoes
      • Apr 2005
      • 524
      • Bangor Maine
      To get the nuts off the stud, get a couple of nuts the same thread as the stud and put them on the both on the cylinder side thread, and tighten them together really tight. Then hold the inside one with a wrench and loosen the exhaust nut. Then just unjam the two nuts. Called double nutting, also works for installing studs.
      Steve
      80 XS1100G Standard - YammerHammer
      73 Yamaha DT3 - DirtyHairy
      62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
      Norton Electra - future restore
      CZ 400 MX'er
      68 Ducati Scrambler
      RC Planes and Helis
      • rover
        • Jan 2004
        • 765
        • central WI (715)
        Since the nut is round, place it on a piece of steel or iron, and tap it with a hammer as you roll it on the steel. Some penetrating oil will help a lot. After a few revolutions and tapping, the nut should come right off the stud.
        put something smooooth betwen your legs, XS eleven
        79 F (Blueballs)
        79 SF (Redbutt)
        81 LH (organ donor)
        79 XS 650S (gone to MC heaven)
        76 CB 750 (gone to MC heaven)
        rover has spoken
