gas tank question
  • bandet01
    • 698
    • connersville indiana
    gas tank question
    ok guys i asked this alittle while back and i kind of found a answer but then my dad said there is a filter and i need to find out if that is true or if what i want to try will work
    my problem is the i have a 79 xs1100 and were the tank is resesed in it gets filled with water or overfilled fuel and it does not drain and when i got for a ride the over flow stuff flys up all over me and i need to find out if that drain in there where it drain to the bottom of the bike has a filter on that line or not and when i take it apart to paint can the line be blown out wioth air or how does it need to be done
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
    The hole should be clear, with NO FILTER. I would just start with trying to run a wire through the tube. A 12Gauge copper wire will work, without going through the tube, unless it's badly rusted. The air compressor will also work, and if it's handy would make a good first try, IMHO.
    Ray
    • bandet01
      • 698
      thanks ray thats what i needed to know
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "Hey, you Hoser!"
        Make sure that the hose that hooks to the fitting on the tank is clear (underneath the bike) and not plugged with crap.
        • portero72
          • Sep 2005
          • 132
          • austin, tx
          Had that problem a few times myself...a low 'E' string off a guitar worked out great for me. Pull the plastic drain hose of the back of the tank (near the seat) and insert from there. It's easier that way-there's a kink near the top of the tank that's hard to pass. The texture of the guitar string will also help loosen any built up crud. My $.02
          79 xs1100F
          75K and counting...
          76k...
          79k...
          80k...
          86k...
          • bandet01
            • 698
            thanks for the advise i will have t see if i can find some gautor strings
