Carb removal
  • JWSanders
    • 879
    • White House, TN
    What if your hair dryer has a turbo? Isn't that more manly?
    Could be the reason I don't have nearly as much hair as I used to. I can go from 0 to dry in 6.5 secs!!
    Then of course, there's always the heat gun....
    80 XS1100SG
    81 XS400SH
    Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
    A Few Animations I've Made
    • pathfinder
      XStremely XSive(Deceased)
      • Apr 2004
      • 483
      • Houston, TX
      Just a tip before you put the airbox back in make sure to turn them all with the titts up. Sounds sexual don't it, it's not. On the intake boots there is a spot on the boot itself that has a little bump right where it goes into the airbox. It need's to be pointed straight up for proper alignment.
      78XS11E
      • CUBuffs
        • 252
        • Castle Rock, Co
        Gnepig supplied this tip earlier:
        "i have removed the top mount from my air box, makes things much easer to move around"
        Just wondering if anyone else has done this as well?
        80 XS11 SG
        79 XS750 SF
        74 KZ400
        78 KZ650
        78 KZ750
