Yamabond #4
  • Mike F
    • 99
    • Amesbury (next to Stonehenge)
    Yamabond #4
    Hi All,
    I've started the big strip down, got all the gaskets but I can't find any Yamabond #4 anywhere.
    Can anyone please help me out? I'd prefer to use the recommended stuff rather than making do.
    Thanks & keep revving
    Mike
    Mike Farnworth
    XS1100 E & XS1100 Sport Project
  • John
    • 5117
    Some bike shops carry a product called either three bond or triple bond. I'm told it is the same stuff as the Yamabond.
    • Mike F
      • 99
      Do you know if they're semi-drying. That way, it's easy to dismantle and also allows a bit of movement through temperature ranges.
      Thanks
      Mike Farnworth
      • John
        • 5117
        Yes they are. I have used the Yamabond on engine cases many times before, and I like it.
        • GNEPIG
          • Apr 2005
          • 1657
          • fl
          .. this is the stuff you want, it's the same stuff as yamabond
          it's the best stuff to use
          • Winterhawk
            • Jun 2004
            • 684
            • Missouri
            Same company makes it for Yamaha. I would trust no other. Had good results with Gasketcinch but will always use Yamabond.
            • Mike F
              • 99
              Thanks for all the info everyone, I'm a lot happier now that I know that I can use something else.
              Thanks
              Mike Farnworth
              • Winterhawk
                • Jun 2004
                • 684
                • Missouri
                I'm sorry, I just saw you mentioned #4.
                An XS1100 has no need for #4. Use Only Yamabond #5 on these. I only use sealer (#5) on valve cover and center case's only.
                The rest of the gaskets gets no sealer at all. This way it won't trash the gaskets. You'll like Yamabond #5, Used it on every XS1100 worked on.
                • randy
                  • Dec 2003
                  • 4521
                  I use permatex #3 on gaskets, gluing them to the cover. Dry on the crankcase. That allows repeated use without having to replace gasket every time.
                  Permatex® Aviation Form-A-Gasket® No. 3 Sealant
                  "Nonhardening liquid gasket sealant/dressing/coating is a thin, brushable dressing or sealer for close-fitting parts. Suitable for continuous temperatures to 400°F (204°C). Resistant to antifreeze, aviation fuels, high-detergent oils and lubricants. Conforms to MIL-S-45180 D."
                  Suggested Applications:
                  Gasket coating or sealing close-fitting machined parts.
                  P/N Container Size Pack Item #
                  3D 16 oz. bottle 12 80017
                  • randy
                    • Dec 2003
                    • 4521
                    Looks like:
                    Wouldn't leave the ground without it!
                    • petejw
                      • 2269
                      • sydney australia
                      i do the same as Randy except i glue mine to the
                      case and smear vasoline on the opposite side
                      to prevent sticking, usually cause if i
                      pull a cover off, i tend to polish it on the buffer.
                      if its a gasket thats placed
                      on something i take off reguarly i smear vasoline
                      on both sides.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • Geezer
                        • May 2003
                        • 2985
                        • Willamina, Oregon 97229
                        Try HondaBond. Honda got tired of their mechanic recomending Yamabond and they started selling the same stuff.
                        Geezer
                        • tranger03
                          • Dec 2005
                          • 19
                          • San Juan Capistrano, CA
                          probably too late
                          found some yamabond at the following website
                          powerpartsplus.com
                          hope this helps. they also have useful diagrams if you search for xs1100 parts.
