tank badges
  • edgo
    • Jul 2005
    • 138
    • Tampa FL
    tank badges
    Wil these fit my 79 Special: http://www.mikesxs.com/mikesxs-acces...ategory_id=8.2
    part number 65-6502
    Ed
    79 XS1100SF
    78 YZ400E
    81 SR500
    79 RM250
    77 YZ400D
    05 RM250
    78 CR 250 Husky w/TT500 motor
  • bandet01
    • 698
    • connersville indiana
    i dont know but i am sure yamaha would be able to tell you i was also woundering the same thing if they would work on a 79 standard
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
      I checked at Yamaha .com, and the prefix of the part number was different, meaning a different part. They may fit just the same. You would have tpo buy one and try it to truly know, or maybe 650 Mike would know.
      • CTSommers
        • Sep 2005
        • 11
        • Philadelphia, PA
        edgo those Tank Badge look like the ones on my XJ750 and if they are they will fit. You see they have very sticky glue like sticker on the back side of the badge.
        1983 XJ750 Midnight Maxim
        • JWSanders
          • 879
          • White House, TN
          if you're looking for a much lower priced alternative, in chrome, check here:
          80 XS1100SG
          81 XS400SH
          Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
          A Few Animations I've Made
          • bandet01
            • 698
            yeah it is a cheap replacement but it aint exact and it wont line up and you have to do alittle modifing to get it to work but i do like the chrome idea over the gold
              Mike's XS badge
              Mike's XS parts are exclusively for the XS650. Sometimes they apply to other XS models as identical. In this case I can assure you that the tank badges from Mike's XS WILL NOT fit the XS1100. I own both bikes. The XS650 wears a smaller badge on its smaller tank.
              • xs650mike
                • 1286
                • Lake County, California
                Re: Mike's XS badge
                Right you are, the holes won't line up but it is possible to just glue the badges on or use double sided tape. Another possibility is this outfit. http://www.badgereplicas.com.au/badges_yamaha.htm Prices are in Aussie $s.
                Shiny side up,
                650 Mike
                XS1100SF "Rusty", runs great, 96k miles
                XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
                Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
                • randy
                  • Dec 2003
                  • 4521
                  I have these replica badges on Swamp Thing. They're super quality, but made of cast metal. Be aware that because they are cast metal, they are just a wee bit smaller than the stock ones they used for their molds. (The metal shrinks when cooling). They're also real gold plated, so they'll NEVER tarnish.
                  That being said, ONE of the holes will be about 1/8" off. I solved this by drilling (ever so carefully) another hole in the tank flange 1/8" aft of the forward hole and tapped it 4mm for the original screws. The screws are still available BTW.
                  It's perfect, but you'll need nerves of steel (or 3+ beers) to get it done without piercing your tank.
                  • MAXIMAN
                    • Jan 2005
                    • 1817
                    The Aussie badges aren't exact either. I bought a set for my '79 Special and they were close...but no cigar.
                    I had to redrill and tap the mounting holes. The manufacture claims the holes are of due to cooling of the metal upon casting...yes these Aussie badges are metal.
                    However I have bought some Yamaha tank badges for an XJ750 Maxim. They have no holes for screw mounts and must be put on with dual sided adhesive tape. They look fine.
                      A friend of mine bought the Aussie badges for his XS-2. They were unsatisfactory. They did provide a full refund however.
                      • randy
                        • Dec 2003
                        • 4521
                        BTW,
                        For those of you who want the Aussie badges, the US distributor is OldBikebarn.com:
                        Oldbikebarn
