another carb problem/carb synch
  • petejw
    • 2269
    • sydney australia
    Thanx TC, was wondering where the thread went to. lol
    Im in Aus, so i bought the seals from yamaha, they werent to badly priced considering they were genuine $4.00 Au each, you need 8 of them.
    my bike is an '81, I dont think they would be any different thru
    the models but im not 100% sure, Its a job well worth doing
    tho the carbies can be a little tricky to completely strip right down
    there is nothing in the clymers that describes the complete tear
    down of the carbs, if ur contemplating doing the seals and u need any advice or tips let me know.
    the part number on the packet ive got is 256-14997-00
    i tried to take som pics of the old seals, but it was 2 blurry.
    they were all hard and lost a lot of its pliability.
    when and if u take the old seals out place them on the throttle shaft and hold up to a light, mine had gaps between the shaft and seal.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • petejw
      • 2269
      • sydney australia
      info on pulling down the carbs
      just curious,
      is there any info on the forums about
      the complete disassembly of the carbies,
      tips etc. if any one is interested i could
      stick sum stuff on here that may b of help
      2 sum who dnt feel to confident about pulling the carbs
      down.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • Brian_D
        • 355
        • Gardner, KS
        The Throttle Butterfly Shaft Seal, Part #48-5021, from MikesXS definitely fit the '81 BS34 CV carb on my XS1100LH.
        They should also fit the earlier carbs as well since the shaft diameter is the same.
