Timer too
In addition to counting pulses there is also a timer, supposed to be 10 sec. You can see the thing really easy. It's on the back of the speedo. A peice of plastic about 1" long and 1/4" wide and it just snaps in a slot and is easy to take out and look at without damaging it. Underneath it is the gears for the Odometer which need some grease now and then to keep them from wearing out. The motorcycle will outlast them if you don't lube 'em. The timer is somewhere else. According to the book, whichever comes first, number of pulses or timer, will cancel the flasher and according to the print it removes the ground from the flasher circute.
