Wondering if there was a circuit anywhere of the self cancelling blinkers on the XS.
auto cancelling blinkers
Are you wanting a wiring diagram? What year? Is yours not working?
I can email you a service manual with schematics in .pdf format."We are often so caught up in our destination that we forget to appreciate the journey." " -
Hey GEEZER or RANDY,
This might be another ITEM you could possiby try to replicate for folks that have bad flashers, but would like to replace them and KEEP their self cancelling feature, but don't want to spend $75.00 for a replacement OEM unit.....IF you can make one much cheaper?
T.C.T. C. Gresham
I've been making circuit boards since I was a teenager. I have a spare flasher unit (I hope) on the parts bike I have. I oughta take it apart and reverse engineer it. I would be nice to actually use my degree for something more than just repairing things
Can't say how soon I can get it done, but I've got all winter, it seems..... used to have a CAD program for such things, wonder where it is.80 XS1100SG
81 XS400SH
Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
A Few Animations I've MadeComment
Mine works OK but I was going to see if I could make it work with LED's without having to load them, seems that would defeat the purpose and the thing will not work without the load.
Maybe a nice engineer from Yamaha may help.........Comment
Sometime back about a year another member posted a part number for a replacement cancelable flasher for about $58. I bought one and it works fine.
I also took it apart to see how it works. It's a relay with an RC network that make it flash, one line from the canceller unit supplies 12V , another pulls to ground to energize the relay. To cancel the cycle there is a line that grounds the cap and discharges it from the other line from the canceler.The relay is apparently in selflatching mode so by pushing the handlebar switch will also cancel the cycle.
All this is from memory so is approximatly correct, if not exactly. The bike is up for the winter, so maybe l'll go out and pull the flasher off to be sure.
Thought about doing one with a microcontroller, but this works and I have lots of other things to do.
Steve80 XS1100G Standard - YammerHammer
73 Yamaha DT3 - DirtyHairy
CZ 400 MX'er
68 Ducati Scrambler
RC Planes and HelisComment
a flasher upgrade would be great
mine doesn't flash unless the motor is running
prob a voltage thing
but it did it with a brand new battery also
hey LoserShoes
hows the weather up there
we have 3 inches on the ground down herehttp://home.securespeed.us/~xswilly/
78E main ride, since birth the "good"
78E Parts, the "bad" fixing up now
78E Parts the "ugly" maybe next year
79F Parts
80G Parts
75 DT 400B enduroComment
Hey JW,
Perhaps you could get one of the electronic flashers for autos, and adapt it for the XS with self cancelling mode, that way we could use it for both standard bulbs and LED's, and still keep our self cancelling function!?
T.C.T. C. Gresham
Here the info on the new part # for the new electronic flasher.
I bit the bullet and ordered a new 1A0-83350-70-00 from DGY Motorsports. They sent Part # 2NV-83355-00-00. The new part is rectangular but comes with its own rubber mount. It works. It fits. And I think its ALL ELECTRONIC.
P.S. Price was 56.27 plus shiping.
P.S.S. That was about nine months ago
Ed zLast edited by e.z.nightrider; 11-27-2005, 08:39 PM.It's an 80 LG My Midnight Ride
81 XJ650 MAXIM The Preachers Bike (Gone but not forgotten)
82 KZ 305 CSR Training Wheels (now my daughters)
82 GS 850 GL SWMBO's (HER RIDE)
'He who wanders is not always lost."Comment
Pulled out my notes from when I was fixing my flashers. The cancel unit is potted so the circuit is a mystery, but to cancel the green/yellow wire goes from open circuit to ground. The tan wire is 12v from the ignition switch, and the tan/white goes to the handelbar switch. These colors are for an 80G, yours maybe different.
You should be able to check this with a voltmeter/ohmmeter. Do you understand how the cancel unit works? There is a counter from the speedo that gives a distance signal, and a timer, the cancel signal is given when either the distance or timer finishs LAST. So if your trying to check things out, you'll have to rotate the front wheel to get the distance counter to complete, or you'll never get a cancel.
Hopes this helps
CZ 400 MX'er
68 Ducati Scrambler
Here's an educated guess:
The "canceller unit" is mostly the timer.
So, if we can rig a bypass, we can use just the distance switch and ditch the 'canceller' unit? - Food for thought.
Never understood the thinking behind the time and distance engineering of that circuit.
If you're not moving, why would you want your signals to cancel?Comment
There is a sensor in the speedometer housing that sends an impulse with each revolution caused by the speedo cable, to the canceller unit.
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
Skids,
I seem to remember (but that fails more often every passing year) that the signals are supposed to cancel after 1/4 mile or (X) time interval.
Is that impulse every revolution of the cable or every 1/4 mile tick of the odometer?
Has anyone actually tested this?Comment
The way it looked to me is that there is a reed sensor that sends the impulse from a wheel inside the odometer. I took that piece off to try to find a place to spray inside. I'd guess the canceller has a counter of some sort, maybe combined with a timer?
I meant the self cancelling unit as well. But I know I have a spare flasher too now. I can't imagine there isnt a modern solid-state equivalent in the myriad of cars out there. I'm sitting here damnning myself bacause I dont have my wiring diagram handy. At the very least I know one could be made..it can't be all that complicated, can it? Does the canceller just unlatch the relay the same as pressing the botton does?
So many questions, and my book is 45 miles away...grrrr.80 XS1100SG
81 XS400SH
