Just gotta keep fussing with the bike, doubt if it will ever be perfect
For the third time in one year, I had another gas leak - okay, that's it, I've had it, time to replumb. I gathered the four petcock taps using two Y connectors, thru another Y (or T) to a fuel shutoff valve. I got the valve at a Yamaha dealer, it is a 1/4" inline shutoff valve w/ 90 deg outlets. WPS part nr 12-7118, $11.95. The handle also has positive stops, rotates 90 deg to definite On and Off positions.
From the shutoff, one could insert a single filter inline before the final T to the carbs.
I gave it a good hard run to see if there were any fuel starvation symptoms, none at all. I didn't expect any, I had flow tested the valve at over 20 oz/min flow. That means 32 minutes to empty the 5 gallon tank, that ought to be enough, I figured.
This arrangement minimizes the number of hoses and fittings, delivers gas to all carbs from whichever side of the tank.
I also was tired of the difficulty of carb removal on the XJ, the airbox barely moves out of the way, the heck with that too. Love the sound when I get on the throttle!
The airbox used to bolt to a tab on the frame behind the left side-cover, a nice place to mount a bracket to attach the shutoff valve (which is designed to be mounted that way, how convenient!) That's the little red handle in the Off position. Rotate the red handle 90 deg toward the carbs for On. I was thinking, gee that bracket kinda sticks out, maybe I should have painted it black, forgetting where it would be when the side cover was back on! Happy accident, that.
Now, if I can just remember to turn it on and off...
Please keep us posted on your progress.
