Carbs
Pickman,I am using;
Mains-137.5
Pilots-45
Air-210
Needles 5GZ6-circlip in the center groove
Float Height-1 3/6"
I am using the stock air box, un-drilled.
I use 2 small plastic in-line filters. One each just off of the petcocks. From there a piece of fuel line across the top of the carbs and then into a piece of 1/4' copper line bent at 90 degrees to direct the fuel down between the carbs with no possibility of a fuel line crimping or folding over and restricting fuel flow. From there more fuel line into the "T" piece into the carbs.
Remember I have a 78E model. The carbs on the 78-79's are different than the 80-81"s.
I have tried the individual cone type air filters. Do not know what brand. I obtained them from XS Mikes Shop in Florida. When they did not work out, (ran away too rich at higher revs) (because of the rubber shoulder in the throat of the filter was smaller than the air horn on the carbs) he refunded my money without any hesitation.
Hope this helps confuse you even more. Tee Hee
Ken/Sooke
78E Ratbyk
82 FT500 "lilRat"
Pickman,I am using;
Mains-137.5
Pilots-45
Air-210
Float Height-1 3/6"
Ken/Sooke
78E Ratbyk
82 FT500 "lilRat"
(Thanks for the link TC...d'oh!)
