while my gas tank gently seeps
  • speedlimit85
    replied
    the sender unit bolts have the same washers as the petcock screws
    be working on that when the gasket arrives
    Leave a comment:
  • speedlimit85
    replied
    Or the sending unit?
    Leave a comment:
  • speedlimit85
    replied
    Still leaking! Looks above the petcock. Is it the tank? This sucks.
    Leave a comment:
    replied
    ACE hardware carries them, so does Lowe's. You will need to buy the 1/4" one and ream it out slightly with sandpaper as described above. I've been running them for a few years on my '79 with no problems.
    Leave a comment:
    replied
    Hardware store, not auto parts
    Leave a comment:
  • speedlimit85
    replied
    Looks like NAPA only has metal washers now.
    Leave a comment:
    replied
    The website is a bit wonky this morning, their eBay store isn't showing one listed. It's run by a couple of ex military guys, VERY well organized operation! Stopped in there a couple of years back for a pair of Honda 3ohm coils, good people all the way around.
    Leave a comment:
  • speedlimit85
    replied
    Originally posted by LAB3
    That one didn't register before.had an extra one of those rolling around my trailer and probably threw it into the trunk when I donated bike. Needed one and used eBay to find it but had to buy two so I had an extra, Motoplane over in Palatka might be worth checking out for a source, they have a well organized operation and most everything they have is listed on their website. A piece of a pool noodle and some tape will work til then based on personal experience.
    Interesting...did not know it existed.
    Leave a comment:
  • speedlimit85
    replied
    M6 6mm screws. Unable to find washers today. ran tank down to reserve will drain tank inthe morning and put washers back right -not leaking at all -but I can't leave it like that .
    Leave a comment:
    replied
    Regarding the tank rubber bushing, someone on on here might have one hanging around from a parts bike.
    If no one chimes in, a junkyard or eBay might work.
    Leave a comment:
    replied
    I used fiber washers from this kit.
Name:	fiber washers.jpg
    Leave a comment:
  • speedlimit85
    replied
ID:	891961 ones missing, mighta put 2 on one side...glad you talked about washers...
    Leave a comment:
  • speedlimit85
    replied
ID:	891958 what do you call a guitar on the back of a motorcycle? Click image for larger version
ID:	891959 a fender
    what do you call a piano on the back of a motorcycle? a yamaha
    Leave a comment:
    replied
    Leave a comment:
  • speedlimit85
    replied
ID:	891955 Click image for larger version
ID:	891952 Click image for larger version
ID:	891953 Click image for larger version
ID:	891954cleaning it made it run better
    Leave a comment:
