Cold Starting Issue
  • Spartanman
    • Mar 2017
    • 19
    • Lake Odessa, MI.
    Cold Starting Issue
    My XS1100 has always been cold blooded but is getting really tempermental in her old age. I've rebuilt the vacuum block, replaced all the octopus fuel lines, new plugs etc.... But even on a warm morning, it can be 5-10 minutes before she'll finally start up, sometimes on full choke, sometimes on half choke, never with no choke. Once warmed up, she runs like a champ and starts up no problem the rest of the day. I think the carbs are OK, only because the plugs look really good and it idles and accelerates without a hiccup. One thing I have noticed is that it starts much easier when the tank is full. After struggling the other day to get it started with about a quarter tank, I filled it up and waited a couple days. This morning, it started on half choke on the second try.
    So, this may be an idiotic thought, but those fuel lines into the octupus have some tight bends. Is it possible that one or more are bent so much they are restricting fuel flow and that the full tank adds just enough pressure to force the fuel through them? Any other thoughts, suggestions are welcome.
    Thanks
    81 xs1100LH
    75 Norton Commando
    • 7812
    Yes, that may be part of it, but it usually keeps the bike from running properly at 55mph as well. I would think the problem is the holes in the float bowel used for the enrichment circuit. Also, do you have ethanol free gas available? If not, that is probably your biggest problem.Ethanol gas in a tank that is NOT FULL will start to go bad and change colors within two weeks. A full tank will go about one month before starting to change. When I know I'm going to park my bike for even a little while, like two weeks, I turn off the fuel and run the carbs dry. When I go to restart, put the petcocks on PRIME for a minute and then turn to on. The special will not flow gas until the engine is running, so you need to start it on prime.
    • Spartanman
      • Mar 2017
      • 19
      • Lake Odessa, MI.
      Thanks. I don't think it's the ethanol. I run a fuel stabilizer year round, and when I take the bike out of storage after 6 months of Michigan winter hibernation, it's not any harder to start than it is now. But I've never used the prime setting on the petcocks. Will give it a try.
      81 xs1100LH
      75 Norton Commando
        • 8889
        Yep, make sure the starter jet is clear down the carb bowl tunnels...
          • 2009
          This sounds like a classic case of valve adjustment issues. The gap on the lash is closed and the valve does not sit tight on the seat. You might actually have low compression issues. No gas is getting sucked into the cylinders on the first stroke. Seen it many times. Check those valves and then do a sync.
            • 289
            Howdy Spartanman,,,,I second with DiverRay,,,,,turn the petcock to prime, wait a few moments,,maybe check the inline fuel filters, hope you have them installed, otherwise put them in,,,,,then turn over and see if that helps,,,,I do it all the time with my 81 venture and it really helps cold start,,,keep us informed,,,,,Mike in S.DIego and Pa
              • 2136
              If you don't find any cause in the fuel system, consider cleaning the electrical connectors. If you haven't done it in many years, you'll be surprised how happy the bike will be. Maybe even the turn signal cancel will work.
                • 8889
                This right here convinces me that most/all of the four enrichment circuits are plugged up. The bike would be very hard to start with only one or no cylinders firing when cold.
                  • 5073
                  Originally posted by Spartanman
                  (snip) it can be 5-10 minutes before she'll finally start up, sometimes on full choke, sometimes on half choke, never with no choke. Once warmed up, she runs like a champ and starts up no problem the rest of the day.(snip)
                  Thanks
                  If you are getting any flow at all, even restricted flow, it might me worthwhile to do an "Itallian tune up" with Techron complete fuel system and injectotr cleaner.
                    • 812
                    I'm with Deebs, check your valve clearances. Listing everything something COULD be doesn't help much until the most obvious choices have been eliminated.
                      • 3280
                      Slightly off topic, check valve clearances for sure. The '82 Seca 750 that I have posted about elsewhere, is very intermittent on number two cylinder only and number four is always running much hotter on the header pipe by IR thermometer reading.
                      Pulled the valve cover yesterday. #2 exhaust was a tight .004, spec is .006-.008. #4 intake .002, spec is .004-.006
                      Tight exhaust valve could be messing with compression at idle but comes online at higher RPM intermittently. Tight intake valve could possibly lead to a lean mixture which increases temperature to my thinking.
                      Not saying those are the causes, however the only two cylinders I have questions about have tight valves and their symptoms follow the path for which valve is tight in each cylinder, again, to my thinking.
                      I'm sharing the story in case it helps encourage you to check your clearances.
                      ZRX1200
                      Seca 750
                        • 5073
                        Sooo, air,fuel,spark AND compression.
