brake pads
  • speedlimit85
    • Jan 2017
    • 491
    • Gainesville, Fl.
    brake pads
    Looks like I need new ones soon. Will any do or do y'all have preferences?
    80 G
    EBC brand is good but even the cheapest ones will work just fine. I use the cheapest ones with a shim to prevent squeaking. No guarantee the more expensive ones won't squeal.
    • speedlimit85
      • Jan 2017
      • 491
      • Gainesville, Fl.
      https://www.ebay.com/itm/271227537549
      these are cheap..33 bucks
      I went to Yamaha today. They want $140 for aftermarket EBC and they need to order it.
      80 G
        I wouldn't hesitate to use these.
          I’ve been using SBS ceramic pads on my XS11 for a long time. I buy them on eBay.
            I use Sixity. They work great and the price is excellent.
            https://www.ebay.com/itm/16836256502...Bk9SR9yljuHDZw
ID:	889718 Click image for larger version
ID:	889715 Click image for larger version
ID:	889717 Click image for larger version
                I've used the Sixity brand pads that Deebs linked, no need to spend more!
                • speedlimit85
                  • Jan 2017
                  • 491
                  • Gainesville, Fl.
                  gonna use the disc brake quiet or build shims like biker Phil in an old thread or both.
                  80 G
Name:	XS11 brake pad shims.jpg
                      Mike's XS has the shims for $11.29 per caliper or for $30 you can get a set of four pads and two sets of shims.
                      https://www.mikesxs.net/yamaha-xs650...045-02-00.html
                        • 5073
                        Me too, but some of the cheap ones have backing plates that do not fit. Squeaky brakes drive me crazy and mine have been like that for years.
                          Yep, I've run into some cheap pads that required some filing of the metal slots to get them to fit properly without binding.
                            Yep, it's cool to build your own sometimes. I used some shims from an old Volvo I believe it was. They are rectangular and nice SS with the right thickness.
                            With a vice and a hammer, you can make some nice sharp 90 deg. bends.
                            Click image for larger version  Name:	IMG_20260513_230229.jpg Views:	0 Size:	155.1 KB ID:	889736
                            • speedlimit85
                              • Jan 2017
                              • 491
                              • Gainesville, Fl.
                              The manual says the front and rear pads look the same but are not safe to interchange. I just got 3 sets thinking they're the same. Are the aftermarket pads ok for front and rear? Or did I just get 3 sets of rear pads?
                              80 G
