Weird Starter
  • barrelguy
    • 176
    • Oliver, BC
    Weird Starter
    Over the winter I installed a new handlebar starter switch from MikesXS. Worked fine. Recently I did the carbs and still the switch worked fine. The battery was old and crappy but it got the bile started with the charger connected. Now the fun part - I put in a new battery, turned the key, pushed the start button and nuthin'. Ignition and neutral lights came on, weak horn and signals so I connected the charger and still nothing with the key. Shorted the solenoid with the key on and it fired up nicely. Turned the key off and it just continued running. Had to choke it to stop it. Any words of wisdom out there? Thanks in advance.
    1980 XS 1100 Special
    Mostly stock & original
    Added Yamaha fairing (w/ 8-track!)
    Torpedo bags
    New paint (still) pending
    Stainless brake lines
    Tkat forkbrace
    Coils from Honda 1000
    Previous bikes:
    1968(?) 350 Harley Davidson
    1977 Yamaha 650
    • 8077
    MikesXS switch? It’s probably roached. Good used is often better than MikesXS parts.
      • 7830
      Check ALL THE GROUND wires on the bike! Take the screw/bolt off, clean, put on some anti-seize or no-ox then re- install.
      This is probably 60% of the problems with these bikes now. I would also clean every wire connection just to make sure all is good.
      • speedlimit85
        • Jan 2017
        • 454
        • Gainesville, Fl.
        The button breaks and the spring shorts out and keeps starting. Take it apart see if the spring it may be jammed out of place.
        80 G
        • speedlimit85
          • Jan 2017
          • 454
          • Gainesville, Fl.
          Kept starting with the key off may also be another short.
          80 G
            • 2160
            Usually that problem is caused by the starter solenoid contacts welded together. You can easily check with an Ohmmeter
              I second what Jetmechmarty said about the Mike's XS switch. ( •_•)
              If you had a used-but-good OEM switch then at least someone here could verify what wire(s) in the switch were connected and where in a functional/good setup for a comparision. ( ͡° ͜ʖ ͡° )
              But since it's an aftermarket switch and that's the last corrective action you took before this "event"? (O_o)
              I'm thinkin' they're connected and in a bad kinda way. (•﹏•)
              Kinda hobbled here on my end because I don't know the model/year of your bike and the wiring differs from model/year to model/year... ( 。-_-。)
              On some models when the starter solenoid is energized the red/white wire connected to it sends voltage to the TCI which then bypasses the coil ballast resistor and provides a higher voltage to the coils so there's that hotter spark for starting the bike. (^_^)
              However... if the starter solenoid STAYS energized that voltage also stays and in your situation might just be the reason the engine kept running. (O_O)
              I would suggest disconnecting the "new" battery and then testing with a multimeter to see if-
              1. The starter solenoid turns OFF after being turned on.
              2. The key/switch actually operates as a true off/on for the ignition power.
              I would not do any "trial-and-error" run tests until I knew for CERTAIN that whatever caused the "runaway starter" was fixed.
              HTH...
                • 2057
                I used these aftermarket XS650 switches. High quality and have been very reliable for several years/many miles. However, you have to map out the switches and splice them into your existing harness plugs.
                https://www.ebay.com/itm/323921392821
Name:	XS650 switch on an XS11.jpg
ID:	888939 Click image for larger version
ID:	888940 Click image for larger version
ID:	888941 Click image for larger version
ID:	888942 Click image for larger version
                • barrelguy
                  • 176
                  • Oliver, BC
                  Thanks all - I'll see what I can do. All helpful advice.
                  Torpedo bags
                  Tkat forkbrace
                  Previous bikes:
                  1977 Yamaha 650
                    • 2057
                    Bad contacts on the key/ignition switch. Perhaps needs to be disassembled and cleaned.
                    • barrelguy
                      • 176
                      • Oliver, BC
                      It continues. Worked the issue back to a possibly bad connector block. Took this right out and just connected the wires, colour to colour of course. Ignition key and switch appeared to work as they should. Didn't start the bike as the tank was off but the engine turned over just fine. Next morning I put a wrap on the wires, turned the key on and without pushing the start button it just started turning over non-stop, even when i turned the key off. Had to disconnect the battery ground. I’ll try a different solenoid, clean the ignition and make sure I didn’t pinch any wires. Good thing I’m retired and have all this time! Regardless the bike will be up for sale as I’m not really riding any more.
                      Torpedo bags
                      Tkat forkbrace
                      Previous bikes:
                      1977 Yamaha 650
                        • 2057
                        Starter relay could be shorted or the start button could be shorted. The blue and white wire activates the relay when the start button grounds it at the handlebars. There is a connector with two wires at the solenoid. Try disconnecting the connector.
                          • 2057
                          If needed, the only aftermarket solenoid that is a quality unit is from Rick's. I run one on my sidecar rig. The rest are Chinese garbage.
Name:	Ricks start solenoid.jpg
