high rpm miss
  • edgo
    • Jul 2005
    • 138
    • Tampa FL
    high rpm miss
    I've got a breakup at high rpms in all gears, I'm guessing at 6k and above rpms, my tach sucks. It starts with a little choke and it idles fine and chugs around at 2K rpms very smoothly. The pilot circuit seems good. It revs freely in neutral all the way to redline. When it's on the road in 5th gear in gets rough at 70mph. It will slowly climb but is very sluggish and rough like it is running out of gas. My carbs are stock 79sf and I went to 140 mains with pod filters and 4 into 2 Jardens. It did this with 137.5 mains too. Float height is 25mm.
    What do I check next?
    Thanks,
    Ed
    79 XS1100SF
    78 YZ400E
    81 SR500
    79 RM250
    77 YZ400D
    05 RM250
    78 CR 250 Husky w/TT500 motor
    Pull the plugs and tell us what you see....
    • GNEPIG
      • Apr 2005
      • 1657
      • fl
      .. hello Ed, have you tried removing the pod filters and going for a ride to see what happens?.. also you might want to check the fuel filters on your fuel valves, on these old bikes sometimes stuff can plug them up and cause a low fuel flow.. there are also little fuel screens on top of the needles and seats in the float bowl, i just remove those and put in in line fuel filters
      • petejw
        • 2269
        • sydney australia
        If the break down is occurring under load,
        check out ur spark plug leads.
        pete
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • edgo
          • Jul 2005
          • 138
          • Tampa FL
          I cleaned the carbs but didn't clean those screens. I'll do that next and I have a spare set of coils with new wires installed. So I guess I'm on the right track, I just need yet another weekend.
          Thanks,
          Ed
          79 XS1100SF
          78 YZ400E
          81 SR500
          79 RM250
          77 YZ400D
          05 RM250
          • chevy45412001
            • Mar 2003
            • 1412
            • Jacksonville Florida
            filters
            i had the same prob. turned out being fuel filters were pretty dirty. Or not able to flow enough fuel to supply the higher rpm's.Just a thought.
            1982 XJ 1100
            • edgo
              • Jul 2005
              • 138
              • Tampa FL
              Thanks. My first thought when it did this was that it was starving for fuel. I'll check it out.
              Ed
              79 XS1100SF
              78 YZ400E
              81 SR500
              79 RM250
              77 YZ400D
              05 RM250
              • pggg
                • 1609
                • NZ
                Mmmm... restricted fuel filters.. heh heh.. say no more..
                • edgo
                  • Jul 2005
                  • 138
                  • Tampa FL
                  My wife wants to know why would I need the bike to go over 80mph.
                  Ed
                  79 XS1100SF
                  78 YZ400E
                  81 SR500
                  79 RM250
                  77 YZ400D
                  05 RM250
                    Tell her need has nothing to do with it!
                    • jimboreeno
                      • 427
                      • Smithville, MO
                      Tell her, "It's to enhance my safe riding. In case I am next to a semi and it begins to merge into my lane, and there is another semi right behind me so I can't slow quickly."
                      We must be able to make sure we are safe when we ride...musn't we??
                      JimBoReeno
                      My Ex!"Half-Breed"
                      '82 XJ1100 Maxim with
                      '80 XS1100SG Motor
                      Current Bike
                      2000 Indian Chief
                      Millennium Edition
                      • xj11john
                        • Jun 2005
                        • 440
                        • Lafayette, TN
                        jimboreeno
                        Hmmm. good one I'll have to store that one in the deep dark recesses of my cranium
                        '82 Xj1100j
                        "Ride for the Son"
                        John
                        • cueball
                          • Jun 2003
                          • 375
                          • Nth Albury NSW Australia 2640
                          By asking the question, she is already letting you know that she would not understand the answer.
                          • xj11john
                            • Jun 2005
                            • 440
                            • Lafayette, TN
                            Edgo,
                            Heres a tech tip that may help.
                            Here one part that several have had happen concering the gas cap. #3.
                            1. Try moving the pet-cocks to the reserve and prime positions.
                            2. Try experimenting with the carb enricher (choke) lever.
                            3. Try opening your gas tank (if the vent gets plugged you will experience gas starvation)
                            '82 Xj1100j
                            "Ride for the Son"
                            John
                            • edgo
                              • Jul 2005
                              • 138
                              • Tampa FL
                              I put the new coils with new wires in it and the miss was still there. I then raised up the floats to richen it up and I took off the pod filters. The miss comes and goes now as I play with the petcocks so I think it is still starving for fuel.
                              I like the pod filters and don't want to put the airbox back on. Where can I get some that won't choke the bike?
                              When it gets fuel it really gets up and goes. My floats are at about one inch now whick is a little over 26mm. I don't have a metric caliper. Should I go up a bit more on the floats or go to 142 main jets?
                              Ed
                              79 XS1100SF
                              78 YZ400E
                              81 SR500
                              79 RM250
                              77 YZ400D
                              05 RM250
