i've gotten to the carbs on my project and the old gas has chrystalized. there are only small deposits in the carbs themselves, and carb cleaner is doing fine on the one i've started on, but i still have 2 questions. 1) will prolonged soaking in carb cleaner cause deterioration of the gaskets? 2) same question for the fuel line fittings, 3) and is it safe to use a soft (baby) tooth brush to clean with?
Just To Be Sure...
Yes, if you're using the carb cleaner in a bucket that you soak the carbs in. Too rough for rubber gaskets, seals and plastic parts. Use a NON-clorinated spray carb cleaner instead.will prolonged soaking in carb cleaner cause deterioration of the gaskets?Yes, but clean it afterwards before sticking it back in the baby's mouth... and don't tell your wife about it!) and is it safe to use a soft (baby) tooth brush to clean with?"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy) -
ROTFLMAO!
origianally posted by valhallan
Prometheus, that was good advice, I'm still laughing!!
HEEEHEEEHAAAHAAA!Last edited by xj11john; 11-21-2005, 05:09 PM.'82 Xj1100j
"Ride for the Son"
JohnComment
