XS1100 Woodchipper
  • Lars Helly
    • Mar 2025
    • 10
    XS1100 Woodchipper
    I'm 85% of the way through an entire chopper overhaul. All that left is wiring and breaks, neither of which should be a struggle. Sadly, my progress has screeched to a halt due to some unforeseen circumstances and a foolish series of events. Long story short, I broke the end of a pencil width wooden dowel off inside one of my cylinders through the spark plug hole. Don't ask. Pulling the engine is an absolute last resort. The custom frame and drive shaft setup I have makes engine installation a friendship ending task between myself and whoever I trick into helping me. Before I resort to that, I was wondering if anyone had any tips or ides to remove said dowel. I've already tried shop vac to the hole and compressor through the header. Any and all ideas are welcome. Considering turning it over and hoping it trash compacts that thing..
  • Ccitis
    • Jun 2023
    • 207
    Do you have one of those wire extraction tools? Push the plunger to open the jaws. It should fit in there. Get the piston TDC, fish for it. Going to take awhile. I would also try fishing with something very sticky... duct tape wrapped on a flathead... be careful not to lose the tape. I personally would not turn the bike over.... I guess worst case the wood could burn up but it also could mash the plug or top of the head. I think you can get it. I might even try to burn it inside the cylinder lol, but don't take my ideas lol. Next time, metal dowel. Let us know how it goes.
      • 2140
      I would find the biggest pipe tubing that will fit through the spark plug hole. Thin-walled is better.
      I would move the piston away from TDC with the exhaust valve open. This gives the dowel room to move and allows air flow through the cylinder.
      Then I would duct tape the tube on the end of the shopvac, and insert it into the spark hole repeatedly until you get lucky.
      The trick is to get the end of the dowel oriented to go through the spark plug hole.
      Good luck however you proceed.
        • 1987
        Looked at your profile and have no idea where you are from. With that said I would get my hands on a cheap borescope so that I could see. Might make it easier to fashion something to retrieve the dowel if you know specifically where it is. The scopes can be had fairly inexpensively here in the states from several different vendors. A simple search for borescope or endoscope yields several vendors to choose from.
          • 2011
          This will do it.
            • 2140
            This will do it.
            Also good for cleaning the coils under the refrigerator! (I tape it to a yardstick)
            • Ccitis
              • Jun 2023
              • 207
              Amazon has very cheap borescopes. Good point.
                • 5073
                If that was a wooden graphite pencil, I wouldn't sweat it too munch. Here is what to do when you have to install new spark plug threads. You need to attach a shop vac set to blowing onto the exhaust pipe. Rotate the timing so that it is blowing out the spark plug hole. If you have dual mufflers, you might have to figure out what is optimal and maybe tape off the side you don't need. If this can bring out metal shards, it will certainly blow out pencil parts.
                  • 813
                  This thought just came to me and I haven't thought it all the way through but here goes! Drop a little bit of diesel fuel in the cylinder, let the wood soak it up for a bit then light it on fire.
                  • Ccitis
                    • Jun 2023
                    • 207
                    I said the same... burn it in there... lol but I also put the disclaimer not to take my advice haha. Depending how big it is, I would still confirm with a borescope. And who doesn't need to make excuses to buy more tools and toys.
                      • 2011
                      Send in hungry termites.
                      • Lars Helly
                        • Mar 2025
                        • 10
                        Update: had some time today to work on it and finally got it out. I ended up getting a borescope and using it to find where the dowel was. Turns out it was wedged between the valve and the piston head, so i took off the stator cover and turned back the pistons using a wrench on that bolt. This freed the dowel. After that, I used a shop vac with a funnel on the end which brought it vertically up to the hole. From there I tried to hook it with a small pick, but it fell back in. Luckily the piston was in just the right position, so when it fell it stayed vertical, pinned between the piston head and the pick. I was able to hook it into the wood and pull it out. It was much bigger than I thought it was so I'm glad I didn't try to wood chip it. I really appreciate all the helpful tips.
                          • 1987
                          Glad to hear you got it out. You might want to check your compression and do a valve adjustment unless you know for sure no damage was done. Not a bad idea to check valve clearances anyways.
