vac line off #2 carb going to vac advance blocked with a bearing inside the line.
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    Well I have worked on these bikes since the early 80's and have never ever seen this. I am one of the old timers here who cant ride anymore and was helping out one of the younger gents with his bike. It would not go above 3k rpm. The bike is new to him and no history. 79 standard. I told him we will take off the carbs and clean them up. Could be the emulsion tubes or something he never had them off and just got it to a running stage idles beautifully. In removing the carbs noticed a budge in the vac advance line it was a silver ball bearing blocking the line. Any ideas why? I have removed and will check the advance but this has me puzzled?
    82 XJ1100J
    81 Venturer
    • 7792
    It could be the advance unit had the diaphragm fail and that was "the fix". I would test the advance with a vacuum pump before going much farther. If it's bad, you will need to try and locate a good used one, as they are NLA as far as I know. If it checks out good, it may have been "rattling" because of being connected to the carb holder port and not the carb port.
    • LoftCol
      • Jul 2025
      • 51
      • UK
      I found similar on mine. I believe the carbs had been changed at some time for a set that didn't have a vacuum advance connection. My work around , with the help of a mate of mine, was to connect the vacuum advance to the balancing port on number two. I also fitted a small airline regulator that I adjusted gradually until I got it to run reasonably smoothly. There seems to be a dead spot up to 3000 revs, once past it no problems. I have managed to get a set of the correct carbs, which I will fit over winter.
      • Eastcoaster
        • Jan 2012
        • 508
        • oceancity NJ
        Thanks Guys for pointing me in the right direction i have not worked on a bike in years and was helping this young gent out with his new find.
        i did put the vacuum Gague on no vacuum opened up the cover I guess the PO never did the line was off the diaphragm I guess his solution was the bearing in the line reconnected held and worked fine. I cleaned and synced the carbs and a few other things. I think this lad was completely shocked at what these bikes can do he is thrilled with his find and I was probably more thrilled to help. Thanks guys for the sanity check
        82 XJ1100J
        81 Venturer
        • LenB
          • Nov 2020
          • 159
          • Winnipeg, Manitoba, Canada
          Does sound like a pooched vacuum advance. However I would also recommend checking the continuity of the pickup leads, a very common problem. Mine failed when the bike had warmed up enough to cause the insulation on the wires to stretch, pulling the fatigued wires apart. The ball bearing "fix" would probably give you power to a certain RPM past which that crazy advance curve wasn't there anymore and it would run like crap, but it wouldn't die.
          1980 XS1100G (one owner-me)
          1984 Honda VF750S V45
          Owned - 1976 XS750D
          Owned - 1972 Honda CB750
          Owned - (unknown year) XS650
          • speedlimit85
            • Jan 2017
            • 445
            • Gainesville, Fl.
            I did this as a roadside repair. Pinch the vacuum line with a zip tie can make the bike run right. Then repair the wires at home instead of the side of the road.
            80 G
              • 1972
              https://www.ebay.com/itm/35712078384...Bk9SR_rLq9q7Zg
