Just picked up my first 1979 xs1100 special, so just diving into parts availability. Can anyone provide information about the rotors as to what other years are compatible or new part options?
Compatible rotors?
Tags: None👍 1
All year model rotors are compatible. The difference being that the earlier rotors were not slotted. They all still work though. You can do a search for replacement rotors on Ebay. Of course some are better then others. I have never had the need for aftermarket but several of our users may chime in with their reviews of those they have used.2 - 80 LGs bought one new
Jim👍 1 -
Just wanted to add that starting with the 1980 specials they slotted the area that the brake pads rub against. Because of those slots they had to indicate which were for the right side and left side and marked them with an L and R. The rear disc also has an R on them and can be used on the rear or the right front. The 80 standard still had the solid unslotted discs. I have never owned any of the standards but I would think that the discs are completely universal and can be used on the front, left or right side. Quite a while back now we had many users that actually drilled multiple holes in them in a pattern. The premise being that with those holes as well as the slotted ones kept the rotors from getting so hot.2 - 80 LGs bought one new
JimComment
It wasn't for heat, it was to stop in the rain! I had my then brand new 1978 rotors drilled at a machine shop for that reason. I lived just South of San Jose, CA at the time and was able to ride year-round. My first ride in the wet in late '77 had me go through a stop sign with all the brakes applied! That is when I had the rotors drilled, and it stopped no matter what after that.Ray Matteis
It was actually for both. I hadn't thought about rainy conditions. One of the drawbacks to the holes or slots is that the pads wear quicker. I guess the benefits outweigh that.2 - 80 LGs bought one new
JimComment
You had a very good experience with those pads. I had googled the pros and cons of drilled rotors on motorcycles and AI, which you have to take into consideration stated one of the cons would be added pad wear as well as in certain conditions cracks developing between the holes. I also did a search on the later slotted all the way through rotors on the later xs1100's and AI basically said it can cause catastrophic failure, which we all know is not true.2 - 80 LGs bought one new
JimComment
As I said, a machine shop did the drilling, and there was a clean up on the holes. You should ALWAYS just tap the holes with a bigger drill to chamfer them. This takes off the hard edge that causes pad wear and rotor failures.Ray Matteis
For stock replacement, you can use XS650 rotors. It’s the same seven pound rotor. There are takeoffs and aftermarket rotors that fit and perform better. XS650 search will prove more fruitful.Marty (in Mississippi)
XS650EComment
Here's something worth checking out. Some of us tried the Niche Industries floating rotors with varying results, they're WAY lower priced than the other choices out there.
Recently I've seen THIS brand pop up, with them being shipped out of China I'd be leery of getting burned but for someone willing to take the chance these are hard to beat price wise.
https://www.ebay.com/itm/3160593950921980 XS1100G
Intelligent people discuss ideas, average people discuss events, petty people discuss other people.Comment
Yeah, it was your report that steered me clear of buying them. My rear rotor was eaten up pretty bad and I took the chance on getting a used stock unit off eBay which is what I'm running now.
The Sixity brand pads are holding up amazingly well and at $22 for three sets they're hard to beat. I'm getting about 20k miles out of my rear and my fronts probably have 40k on them, they appear to only be half worn. Could very well be I rely too much on my rear.1980 XS1100G
I have straightened the front factory rotors for warp without removing them, right there on the bike with a C-clamp and a dial indicator attached to the fork leg. If they are more than .005" out, you will feel it in the lever.
Sorry, no pictures.
☮Comment
