Another Brake Hangup
  • Supersport396
    • Nov 2024
    • 61
    • NJ
    So my front brake is dragging and taking a test drive locally I was lucky to get home. If I crack the bleeders it rolls free so I'm sure it's the splooge valve. It will happen again in short order. My worry is I can't seem to get the reservoir off without possibly destroying it and or being able to get a correct o ring let alone reinstalling it. I have this type, not the one that came on it with the pull back bars (1980).
    Is there a replacement master I can get that isn't junk?
    • 2020
    You don't need to remove the nylon reservoir bowl to clean the spooge hole.
    Just find the tiny (smaller) hole in he bottom of the reservoir and push a fine wire through it.
      • 1647
      If after you clean out the spooge hole and you still have brake drag you may have to clean under your caliper piston seals.
      • Supersport396
        • Nov 2024
        • 61
        • NJ
        PO says he rebuilt calipers last year and when I crack the bleeders it frees instantly I’m hoping it’s just the splooge.
        so the holes in the reservoir are directly over the splooge?
        • Supersport396
          • Nov 2024
          • 61
          • NJ
          I can’t seem to find a hole. I’m using an 011 guitar wire. Poking around for a while no luck.
            • 8736
            You will need to remove the plastic reservoir completely to gain access to the spooge hole, and to clean it, a thin wire is necessary. Twist, pull, and pry it off, it is tough and shouldn't break.
            • Supersport396
              • Nov 2024
              • 61
              • NJ
              Boy you were right thank you for that advice. That thing was plugged up solid. I used a zero .011 guitar string to clean it up. Cleaned everything up will attempt to use the old O-ring. I put a little bit of ultra gray along the flat area of the master in case it leaks.
                • 1647
                A quality replacement as you had asked.
Name:	16 mm Brembo.jpg
                  • 8736
                  A trick I learned when using the old O- Ring is to wrap the reservoir with a couple of layers of Teflon tape, lube it and reinstall. I've used the white and the yellow type with success.
                  Click image for larger version  Name:	IMG_20250426_220533.jpg Views:	0 Size:	109.0 KB ID:	884410
                  • Supersport396
                    • Nov 2024
                    • 61
                    • NJ
                    Brakes work great! Spooge hole was the culprit. Thank you all for the help/advice!!
                      • 1861
                      May seem like overkill but get into the habit of completely refreshing all of the brake fluid every couple of years and you won't have to deal with that crud anymore. Invest in a mity vac or something similar and it will make doing the job much easier.
                      • Supersport396
                        • Nov 2024
                        • 61
                        • NJ
                        I do have a Mighty Vac....system had been converted to DOT 5 but PO who rebuilt the master did not clear the spooge. If I do have any problems in the future, I will go back to DOT 3-4.
                          • 2020
                          I'm not sure there is a "going back". Have you tried washing DOT5 off any parts? Seems hopeless to me.
                          • Supersport396
                            • Nov 2024
                            • 61
                            • NJ
                            Yes, clean with denatured alcohol, rebuild everything, flush lines with it. I know it's extremely difficult to manage in a painting environment but you just have to be thorough here. I've done it on cars.
