Another Brake Hangup
  • Supersport396
    • Nov 2024
    • 44
    • NJ
    So my front brake is dragging and taking a test drive locally I was lucky to get home. If I crack the bleeders it rolls free so I'm sure it's the splooge valve. It will happen again in short order. My worry is I can't seem to get the reservoir off without possibly destroying it and or being able to get a correct o ring let alone reinstalling it. I have this type, not the one that came on it with the pull back bars (1980).
    Is there a replacement master I can get that isn't junk?
    • 1934
    You don't need to remove the nylon reservoir bowl to clean the spooge hole.
    Just find the tiny (smaller) hole in he bottom of the reservoir and push a fine wire through it.
      • 1389
      If after you clean out the spooge hole and you still have brake drag you may have to clean under your caliper piston seals.
      • Supersport396
        • Nov 2024
        • 44
        • NJ
        PO says he rebuilt calipers last year and when I crack the bleeders it frees instantly I’m hoping it’s just the splooge.
        so the holes in the reservoir are directly over the splooge?
