Primary chain upper guide
  • Rasputin
    • 3189
    • Lacombe, Alberta, Canada
    Wondering if any have had the experience of changing the Primary chain upper guide? Is there any way to get at it without splitting the cases.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
  • Mika.jones
    • Feb 2025
    • 1
    If you're talking about the one between the cam sprockets. I got mine in and out by just unbolting the sprockets and hand lifting the chain. Had to tug with some force but it cleared and swapped without any real issue
    • Rasputin
      • 3189
      Nope this is down on the Primary chain according to the parts fiche. I can find no pictures of it anywhere, just pictures of the primary chain itself.
      2-79 XS1100 SF
        • 8736
        Here's a pic that shows it. Looks like the cases must be split and the crank removed to access.
        Click image for larger version  Name:	Screenshot_20250224-173131.png Views:	0 Size:	385.0 KB ID:	883380
        • Rasputin
          • 3189
          That picture pretty much explains that indeed the cases will need splitting Thanks very much!
          2-79 XS1100 SF
            • 7692
            If you are going that far, replace the chain as well. Parts WILL be hard to find new, and some N.L.A. I'm in the middle of a full rebuild, and one bearing I need will be here on the 28th, of next month! I could not find a chain guide, so I'm putting in a used one I have that still looks good.
            • Rasputin
              • 3189
              This post is more for a buddies issue and i am not sure if he is aware that the guide may not be available. Good info.
              2-79 XS1100 SF
                • 8736
                Used on on eBay.....
