airbox seal
  • aquamantx
    • Aug 2015
    • 198
    • Montgomery, TX
    airbox seal
    While reassembling the airbox I noticed a cap on the bottom that has a hole that is post filter. The parts diagram shows a seal which as you guessed is unavailable. has Anyone seen this and possibly have a suggestion for a media to replace it.
    81 LH in process
    09 vstar 1300
    only allowed 2
    My Specials have a drain hole in the middle of the airbox bottom. I cut a piece of filter material from a HEPA indoor drum air filter and put it in there to keep the dirt and bugs out, yet allow it to drain.
    If yours is the same drain hole, you can look around the house and find something that will work as a filter.
    I see the OEM part is actually available at Partzilla:
    • aquamantx
      • Aug 2015
      • 198
      • Montgomery, TX
      I was looking for some heavy filter media to fill the space. thank you for the info on partzilla.
      81 LH in process
      09 vstar 1300
      only allowed 2
        https://www.ebay.com/itm/22601649048...Bk9SR_S-_diBZQ
Name:	Opera Snapshot_2024-12-28_090052_www.ebay.com.png
          You can also find similar material at a farm supply store such as Tractor Supply or similar type place. The only reason I mention that is because it's generally cheaper there.
          • aquamantx
            • Aug 2015
            • 198
            • Montgomery, TX
            thanks for the info. went with a scotch bright back and a foam top piece.
            81 LH in process
            09 vstar 1300
            only allowed 2
