spark plug cap replacement
  • DeanR
    • Jan 2005
    • 1484
    • Finger Lakes NY
    Sorry about a basic question:
    I just pulled a cap off a plug wire by accident and don't know how to re-attach. I think I remember reading here that they screw on. Did a search but didn't find it. Any tips? Thanks!
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • xs650mike
    • 1286
    • Lake County, California
    Yep they do. Take the rubber boot off of it and slide it onto the wire then screw the plug cap onto the wire. Slide the boot down onto the plug cap. Done!
    Shiny side up,
    650 Mike
    XS1100SF "Rusty", runs great, 96k miles
    XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
    Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
    • DeanR
      • Jan 2005
      • 1484
      • Finger Lakes NY
      So that's all there is to making a solid connection on a pretty important wire??
      Thanks Mike
      (it does seem tight)!
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        technique
        Also, if your wires are still long enough to reach the plugs, it's a good idea to clip off a 1/4 inch of the wire before attaching the cap. Wire ends tend to get corroded over time. Depends how they look, I say.
        • xs650mike
          • 1286
          Amen to what Promethius said. But remember, these are high-tension leads and minor gaps will easily be jumped by the 10s of thousands of volts, after all the current has no prob jumping the spark plug gap. You just need the connection to be solid enough that the lead doesn't fall off of the plug cap.
          Shiny side up,
          650 Mike
