4 bent valves and more!
    • 5058
    Nope.
    Originally posted by petejw
    mine was the same was just curious if they sold the chain with the master link with a clip.
    pete.
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      Master link... rivet type
      • petejw
        • 2269
        • sydney australia
        Ive finally got the head back this arvo and
        put it all back together, problem was it was
        getting 2 late, i was able to get it running but the
        carbs, mixture screws are out of adjustment.
        i piss the neighbours off at the best of times starting
        the bike at all hrs to go for rides, so ill have to make adj tomorrow. After a blip on the throttle she revs right out and wont go down to an idle, while the carbs were off i bench sync
        them and adj the float levels.
        pete
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • Ducky
          • Dec 2004
          • 11
          • Qualicum Beach, B.C.
          Mikes xs
          Hello:
          where, who, what is "Mikes xs" that is referred to in the above threads?? Looking for a cam chain tool.
          thenk yew
          Ducky
          bikewhse@shaw.ca
          1977 Yamaha 750 triple
          1980 Xs1100 Special
          I have the time:
          Just no Money!!
            Hey Ducky,
            Believe it or not, if you had typed in www.mikesxs.com you would have found it! Another source in www.partsnmore.com ! There are more in the LINK's section!
            Just with Mikes, don't tell them you're ordering for an XS11, or ask them if they know whether the part will fit an xs11, they only know xs650!!
            • caferacer
              • Jun 2006
              • 47
              • effingham il
              dos eney one have some valves that will work on 1980 xs1100 i just replaced the valves and did a head ob last year and no need to do it again i will need valves and hopefully that is it thanks to eneyone that can point me in the right direction
                Hey Cafe,
                Andreas usually has lots of parts, you might check with him?
                You don't have what model you have in your Profile, Standard or Special. It doesn't matter regarding the valves, but does matter for other parts and discussions!
                You didn't say which valves, intake or exhaust. IF you did a head job a year ago, what happened that you need more valves??
                Here's what I've found searching:
                80LG:
                intake: 3H5-12111-01-00
                Exhaust: 3H5-12121-00-00
                bike bandit
                1: VALVE,INTAKE#1 34316-001 $35.87
                2: VALVE,EXHAUST 34317-001 $47.25
                Cycle-Re-Cycle parts www.crc2onlinecatalog.com
                XS1100 '80-'81
                XJ1100 '82
                Intake VLV-2745-IN
                $17.95
                XS1100 '80-'81
                XJ1100 '82
                Exhaust VLV-2746-EX
                $24.95
                • caferacer
                  • Jun 2006
                  • 47
                  • effingham il
                  bent valves
                  t.c. i did the tensioner i herd a click asumed it was in and started the bike it chaterd real bad so i shut it off and ree ajusted then i herd it click the rest of the way in tried to start again and had no compresion the bike is a 1980 h standerd i have about $3500.00 invested in the bike and is total custom i just put new tiers and 4 into one exhaust on it 2 months ago and now this for the prices you gave it would be cheeper to buy a used head to add to my collection
                  • caferacer
                    • Jun 2006
                    • 47
                    • effingham il
                    i am at a point were i dont know what to do i have 3500.00 invested into my 1980 xs1100 standerd custom i just screwed up the valves should i just give up befor i git even farther into it and part it out or sell it as is everything on the bike is perfict iwas just riding it yesterday it ran great pulled a wheely in second geer with no clutch today bent valves what to do?
                    • JWSanders
                      • 879
                      • White House, TN
                      Don't give up on it yet!!
                      It sounds like your tensioner slipped like pete's at the begining of this thread.
                      It's going to cost you a little more time and money, but nothing like what you've already spent. If you do the work yourself, you could fix it for just a couple of hundred more dollars.
                      Finding a used head in good shape would be the easiest way to go. Andreas may have one. There are also several on Ebay:
                      I'd replace the camchain and tensioner, too.
                      All is not lost!!
                      80 XS1100SG
                      81 XS400SH
                      Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
                      A Few Animations I've Made
                        Definitely DON'T GIVE UP!!
                        Hey CafeRacer,
                        You've got one heck of a machine, and a few or even ALL bent valves are not that big a deal to fix! I bent 2 on mine during a topend rebuild just trying to set the shims, turned one cam while the other was still in the head even though the head was OFF the engine , only knew about 1, replaced it, put it all together, did a bench compression test, 0 in 1 cylinder, had to pull it back down and replace that other "slightly" bent valve, got it back together and runs just fine. I only did valve lapping, didn't have to replace any guides!
                        Worse case scenario....4 intake valves =$80.00, 4 Exhaust=$100.00 from CRC2's site, doing all the work yourself. Having run the engine for a season, I don't think you could reuse the head gasket, but perhaps some other more experienced engine rebuilders could chime in on whether you could reuse it!?
                        You'll want to check the cam chain tensioner to see if it's run out of it's adjustment range? IF so..then you might need to replace the cam chain, not sure if you did that when you did your previous head job? If it's new, then your cam chain tensioner just probably has some burrs on the flat locking surface of the tensioner rod, a little filing should smooth it out so that it will slide and lock into proper place the FIRST TIME!! Just check to make sure your locking bolt hasn't stripped out the aluminum threads of the tensioner housing! YOU CAN DO IT!!
                        • caferacer
                          • Jun 2006
                          • 47
                          • effingham il
                          thanks t.c. for the words of encouragement i will do it and mightas well do ring job i will have my shop do the work it will cost more but it will be under a warentey and i dont know if i have the abillity to do it some one just emailed me and offerd me 900.00 for it as is i dont thinck i could let it go that cheep
                            • 5058
                            I would bet a doughnut that the tensioner threads are stripped (like TC indicated it might). You think it is OK and it slipps just enough to keep it in a loose position. Been there/done that and so has Dave Hogue. You can helicoil those threads and make the tensioner better than new.
                              Be advised that stock rings are not available, unless your machine shop is able to fit/modify some rings from an other manufacturer.
                              • caferacer
                                • Jun 2006
                                • 47
                                • effingham il
                                valves please
                                i am buing a used head and pistons will the valves from a 1979 xs1100 standerd or special work for my 1980 xs1100 h and are the pistons and rings the same size????????????
