Headlamp Upgrade 79 xs 1100
  • Mjpcarbon
    • Jul 2024
    • 48
    With my battery drain fixed for now I was wondering if there is a large rectangular headlamp upgrade. I see across the bottom of he bulb it says "Motorcycle" so I am hesitant to put an Auto sealed beam in its place.
    • 3917
    I have a TruckLite LED in mine. Probs a very early LED design. It's terrible.
      • 7641
      I think the '80 had the replaceable bulb in it. You can get a "superbright" LED to replace the halogen bulb. I've done it for my '79 Special and like it. Plenty of light, and less draw on the charging system.
        • 1498
ID:	881703 Click image for larger version
ID:	881701 Click image for larger version
ID:	881702 Click image for larger version
          • 7641
          Try these bulbs! https://www.superbrightleds.com/vehi...&series=173703
          No I don't get anything from them, but I DO like the products they produce.
          • Ccitis
            • Jun 2023
            • 153
            I run an Auxito LED in my bikes. Work great, cheap online... no issues.
              • 1498
              I use Auxito bulbs also. Just restored a CB900C and changed every bulb. Now the bike charges @ 14.5 volts.
                • 697
                Mine was replaced with a plain Jane Sylvania H2 bulb from the local auto parts store, the one already in there was an unidentified knock off of some kind and I can assure you it's quite bright.
                  • 5051
                  Thanks. No need to repeat that on our bikes.
