speedometer needle shaking
  • speedlimit85
    • Jan 2017
    • 434
    • Gainesville, Fl.
    Changed cable, was fixed for a thousand miles. Now started needle shaking again.
    80 G
    • 774
    Did you lube up the Speedo drive? Mine was darn near bone dry when I pulled it apart. Also, make sure the flat washer with the dogs on it between the Speedo drive and wheel is seated properly, I've run mine with it inserted upside down and it worked, until it didn't.
    • speedlimit85
      • Jan 2017
      • 434
      • Gainesville, Fl.
      wd40 in the speedo drive smoothed it out
      80 G
        • 7765
        Use a silicone lube next time! WD40 will dry out quickly, and the problem will return.
          • 8796
          Later down the road, you may find that lubing the cable and drive unit doesn't help anymore. That would be the time for surgery on the speedometer itself, in which it also would like some type of lubricant.
            • 774
            You'll probably want to pack it with wheel bearing grease
            • speedlimit85
              • Jan 2017
              • 434
              • Gainesville, Fl.
              I may be ready to tackle the speedo. Where do I start?
              80 G
                • 8796
                You would remove it from the bike. Then take the rear cover off and remove the wiring harness and set aside. Then comes the fun part, prying the crimp up on the trim ring to gain access to it's guts.
                There are units for sale on eBay, that may be an easier choice. There is a good chance of breaking the needle once it's open. The needle has to be removed/ pried off for 100% proper lubrication.
                • red bandit
                  • 955
                  • central michigan
                  The needle breaks super easy. Barely touch it and it will break. Good luck and be very very careful.
                  79 SF parts bike.
                    • 8796
                    Here is a jig I made on the workbench to hold the speedometer housing while prying up the crimp...
                    Click image for larger version  Name:	IMG_20231015_212527.jpg Views:	0 Size:	185.6 KB ID:	883089
                    Click image for larger version  Name:	IMG_20231015_212619.jpg Views:	0 Size:	179.9 KB ID:	883090
                    Click image for larger version  Name:	IMG_20231015_213311~2.jpg Views:	0 Size:	161.8 KB ID:	883091
                    Once the face plate and needle are removed, then proper lubrication can be applied...
                    • speedlimit85
                      • Jan 2017
                      • 434
                      • Gainesville, Fl.
                      When the needle is shaky is the odometer accurate?
                      80 G
                        • 7765
                        Usually it is. If the "shaking" is caused by a bad cable, then probably not, as it will be missing wheel revolutions.
                          • 2066
                          Somebody correct me if I'm wrong.
                          IIRC, the odometer is mechanically linked to the cable via the gears, but the coupling to the needle is magnetic?
                          Therefore, the odometer will be right, even if the speed might be erratic.
                            • 8796
                            Yes, that's correct, both the speedometer and the odometer are separate from the needle drive, you can see it here...
                            Click image for larger version  Name:	IMG_20250202_231151.jpg Views:	0 Size:	182.0 KB ID:	883123
                            • speedlimit85
                              • Jan 2017
                              • 434
                              • Gainesville, Fl.
                              Share repair: put grease on the end of the cable, jammed it in the speedo, rode the bike, then removed speedo shook it around and reinstalled. No shaking for a couple thousand miles. Click image for larger version
ID:	886632 Click image for larger version
                              80 G
